06-30-2013, 02:24 PM   #1
ISTDL - White images
I have an ISTDL and it's b een working fine until last week when the images are now all coming out white.
If I change the drive mode to Continuous, the 2nd and further shots are all fine, but the 1st of each shutter press is always all white.
I've flashed the firmware to 1.03
Reset the settings to default
Changed the batteries
Cleaned the lenses and body contacts
The body has only a 5300 shutter count
Even shooting with the lens cap on brings up a complete white image.
Any suggestions or Idea's would be greatly appreciated.
I've attached 3 images taken.
The first is what most images come out like, the next two are with drive on continuous - as you can see the second shot (3rd image) is fine - was taken of the TV.
PENTAX *ist DL  Photo
06-30-2013, 03:04 PM   #2
Were these all taken with the same lens? The exif of the first two pics suggests that the lens wasn't properly mounted.
06-30-2013, 03:37 PM   #3
Wrong image selected - they all look very similar. The one above you refer to was taken with the lens off.
Attached this time should be one taken with the same lens.
body, drive, image, images, istdl, pentax help, shutter
istDL battery problem sonofknute Troubleshooting and Beginner Help 15 12-22-2012 08:24 AM
istDL sensor failures grog85361 Pentax DSLR Discussion 5 03-05-2012 09:08 AM
ist DL Producing White/Blank Images? Julie Pentax DSLR Discussion 4 02-11-2012 02:40 AM
Fried istDL sensor? Unregistered Visitors' Center 3 01-23-2012 05:12 PM
istDL billypip Troubleshooting and Beginner Help 9 11-20-2011 09:56 AM
All times are GMT -7. The time now is 05:37 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
