06-30-2013, 07:37 PM   #1
K-r: built-in flash stopped working after using external flash
I mounted an external flash (Quantaray QB6550U with a AF module) on my K-r about a week and a half ago and since then, the internal flash refuses to fire. If I have the flash mode set to auto and conditions warrant it, the flash will pop up, but doesn't fire. I've used the flash with a different (MF) module in the past and never had issues with the internal flash after disconnecting it. I've tried the Reset option in the menu, thinking that maybe some menu setting got changed to cause this. The reset had no effect whatsoever. I also thought that something might be stuck in the hot shoe, so the camera thought an external flash was still mounted, but it doesn't look like anything is there.
Since the e-dial has been acting up a bit lately, it's about time to open her up again and clean that, so I'll check the contacts on the flash, but if there's something else I should try first, I'm open to suggestions.
06-30-2013, 09:10 PM   #2
I had a K-r a long time ago where the pop-up flash stopped working. I sent it in under warranty repair and was told they completely replaced the flash PCB. That's a circuit board, so I don't think there's anything you can do about it unless you send it in.
01-02-2014, 10:11 AM   #3
Eder's Avatar
I have the same problem, i Belive that is why pentax is cheaper than nikon and canon, lots of flaws. I also cleaned my edial because works erratic. I wanted to upgrade to k-5 but i belive will be waste of money. Since im using an external flash i dont care but this shouldn't happen.
01-02-2014, 12:02 PM   #4
QuoteOriginally posted by Eder Quote
Interesting hypothesis.
I would suspect a trigger voltage or polarity issue with the Quantaray flash.
01-02-2014, 12:39 PM   #5
Thats an excellent point . You really have to be careful and make sure the trigger voltage is correct. (and consistent)
i have seen this happen with other camera brands that were using older SLR third vendor hot shoe flashes.
The high end DSLRs might be able to handle it, but midrange and entry level DSLRS might have less robust control boards.
01-02-2014, 01:01 PM   #6
Not a Number's Avatar
QuoteOriginally posted by wedge Quote
ISince the e-dial has been acting up a bit lately, it's about time to open her up again and clean that, so I'll check the contacts on the flash, but if there's something else I should try first, I'm open to suggestions.
Make sure you have a proper resistor to drain the main flash capacitor or you may literally be in for a nasty shock.
01-03-2014, 04:19 AM - 1 Like   #7
Na Horuk's Avatar
Have you ever even held a low-tier Nikon DSLR? Their low tier cameras were more expensive than the K-r, but they feel lighter, use cheaper plastic, and at the time of the K-r they offered fewer features. Google "Nikon flash problems," you will find tonnes of reports of all kinds of problems with the built in flash. Not to mention most of the reports here seem to be people who fried their flash using an off-brand (older? cheaper?) flash. No way can you "hurr it must be the Pentax' fault!" - all digital cameras are sensitive to the voltage of external flashes, its not rocket science. Frankly, you can be glad you only fried your flash and the rest is still working. I would chalk that up to the great Pentax quality, but I think you will refuse to see it that way because you want to believe that Canikon is better. Just don't use that same flash on your D800
01-12-2014, 07:57 PM   #8
In the end, I shipped it off to CRIS and paid on the order of $250 for a new flash unit. The built-in flash has worked beautifully and I've not used that nasty on Quantaray on it since. I did get an AF 360FGZ which I've used on it quite a bit to great affect as well.
Thanks for the opinions and advice.
-Chad
fire, flash, k-r, menu, module, pentax help, reset
How to use built in k-r flash with old lenses Afrikaners Pentax DSLR Discussion 7 06-06-2013 10:12 AM
Need to disable in-built flash when using off camera flash Molly Flashes, Lighting, and Studio 18 03-27-2013 04:12 AM
Using Built in Flash in Wireless mode with External Flash i.e AF-360fgz disco_owner Flashes, Lighting, and Studio 7 05-16-2012 07:41 AM
Using the built-in flash as controller vs. slave external jpzk Pentax Camera and Field Accessories 12 10-13-2011 07:09 PM
In what situation can you use the external flash that the built in flash couldnt? rustynail925 Flashes, Lighting, and Studio 25 01-13-2010 01:26 PM
All times are GMT -7. The time now is 09:45 AM. | See also: NikonForums.com, part of our network of photo forums!
