07-01-2013, 09:33 AM   #1
K-30 # of AF sensors used
In reading through the manual, it appears you can choose to use only the center AF sensor, 5 AF sensors, or all of them. Does anyone have any advice on the some/all AF sensor choices?
Thanks,
Scott
07-01-2013, 09:37 AM   #2
I usually just stick to the center AF point. 11-point af will focus anywhere within the AF area, while 5-point AF will focus just slightly off-center if needed.
07-01-2013, 10:18 AM   #3
mgvh's Avatar
I was using the center point as Adam suggested, but lately I've switched to using the "Select."
BUT... I basically then turn it off (by holding the OK button for a bit), and then it functions as center point select. I do, however, have the option to quick switch to a different focal point by turning it on (again holding OK for a bit) and using the controller to select another point.
07-01-2013, 10:34 AM   #4
Thanks!
07-01-2013, 12:18 PM   #5
JimJohnson's Avatar
Same here. Select focus. I 'park' focus at the center point whenever I have moved it. IF I have sufficient DOF, I'm like a lot of photographers. I use the center focus to select and lock on my target, then recompose the image. I often do a stop-down preview to make sure I have sufficient DOF - I have it programmed in to my RAW/Fx button. However, if the DOF is too shallow for my purposes, I will first compose, followed by moving the focus point with the 4-way control, and finally lock focus with the smallest amount of recomposition possible. After I am done shooting that scene, I move the focus selection point back to center.
07-01-2013, 08:51 PM   #6
Just1MoreDave's Avatar
Eleven points seems like a great idea. More points is better, right? The problem is you won't always agree with the camera's choice of point. It is a gamble to use 11 points on Auto and hope the camera gets it right. I don't even know what the logic is - does it just pick the best contrast?
af, af sensors, camera, pentax help, photography, sensor, sensors
k-30 used ericdesg Pentax K-30 & K-50 4 02-17-2013 08:57 PM
f2.8 AF sensors (K-5 II/IIs) greg_77 Pentax K-5 6 11-24-2012 08:57 AM
new k-30 or used k-5 HSV Pentax DSLR Discussion 11 09-07-2012 09:24 PM
Misc Getting used to the K-30 loco Post Your Photos! 22 08-08-2012 06:03 PM
Will the Pentax K-30's AF rival that of Canikon? Adam Pentax K-30 & K-50 169 07-06-2012 03:33 AM
All times are GMT -7. The time now is 07:55 PM. | See also: NikonForums.com, part of our network of photo forums!
