07-01-2013, 02:36 PM   #1
Kx - Recording Audio with Video
Hello everyone,
Recently I just came into the Digital SLR realm by purchasing a Pentax Kx white "Storm Trooper" camera. I was a little disappointed when I realized that there are no accommodations for an external microphone. So my question is, I KNOW the Kx will do High Definition Video, but how do you get a "Profession" sound (or sound track) with the video? Is the mic' on the Kx sufficient enough?
Also NOTE that I have Cubase recording software that can accommodate both video and multi-channel audio. Can I use this to clean up or enhance the "Audio" of the Hi Def' video from the Kx.
My goal is to make a sort of "Infomercial" for a website I'm thinking of building.
Any help is greatly appreciated.
Thanks,
David
07-01-2013, 02:49 PM   #2
QuoteOriginally posted by guitardude Quote
Hello everyone,
Thanks,
David
Your best bet might be to use an external audio recorder and then merge the tracks using video software. The K-x has a mono mic, so the audio won't be that great, though you can certainly try it and see if it's good enough for your needs
07-01-2013, 03:49 PM   #3
Turn off Image Stabilization, use manual focus (both features are noisy, very much so if using the internal mic).
The mic on the K-x is fine but pretty basic, as Adam says, you're better off using an external recorder if possible.
You know in the movies when they have a clapper-chalkboard and someone says "Take 25" or something and snaps it shut?
That's for syncing the audio and video tracks, you have the visual cue of the board closing and the 'snap' sound. Put the two at the same point and the following audio and video will be in sync.
Of course you can just stand in front of your camera and clap your hands or whatever at the start of each clip.
07-01-2013, 05:16 PM   #4
Anvh's Avatar
There is software that sync everything, it's called pluraleyes
camera, kx, pentax help, photography, sound, video
K-7 overheating CPU with video recording Pete2815 Troubleshooting and Beginner Help 20 04-02-2014 12:06 PM
K-30 Synching 32khz audio with external audio capture devices at other sample rate utrechtnl Video and Pentax HDSLRs 2 02-22-2013 05:30 PM
Limited video recording with K5 Kende Pentax K-5 35 02-07-2013 10:16 PM
kx stops recording video after 30 seconds jupzchris Pentax DSLR Discussion 8 06-20-2010 06:00 AM
Recording problem with KX veebs2 Video and Pentax HDSLRs 10 01-30-2010 04:41 AM
All times are GMT -7. The time now is 11:05 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
