07-03-2013, 03:46 PM   #1
K-30 only focusing on live view with 31mm AL Limited
Hey guys
So, I recently purchased a K-30 to upgrade from my K-7.
Now, my favorite lens, the 31mm AL Limited, works perfectly with my K-7
Upon testing it with the K-30, it simply wouldn't focus. Even if I try manual focus, right at the moment the shutter clicks, the photo 'unfocuses' and comes out completely out of focus.
In my despair, I had the brilliant idea of turning on Live View, and, oddly enough, focus works perfectly, but only in Live View (with both auto and manual focus).
Does anyone have ANY idea of what could be wrong? I tested the K-30 with my other lenses, and it's working fine. I also updated the firmware.
07-03-2013, 04:54 PM   #2
Welcome to the Pentax Forums!
Manual focus fails? Are you remembering to switch AF off before attempting manual focus?
07-03-2013, 07:39 PM   #3
Yes, it doesn't work either way.
07-24-2013, 04:12 PM   #4
Bumping this up in case anyone can shed some light =\
07-27-2013, 07:29 PM   #5
ramseybuckeye's Avatar
I've not read any problem like this before, there may be something simple causing it and sometimes simple things are anything but simple.
On the autofocus settings in the custom menu, what type of priority do you have set?
Does this happen with other lenses?
How are you releasing the shutter, button or remote?
Can you describe step by step how you are shooting? The fact you are coming from a K7 you probably are not doing anything wrong, but maybe somebody will notice something, a setting or perhaps a combination of settings that could cause this.
A call to Pentax service may be next.
07-30-2013, 08:43 AM   #6
It's focus priority, though I've tried the other options. Shutter is released either with timer or by pressing it down, but the focus changes before that. This problem only happens with my 31mm, but this same lens works perfectly with the K-7.
I'm feeling a bit hopeless because I live in Brazil and there is no South America technical support I can call.
31mm, focus, idea, k-30, k-7, pentax help, view
K-30 Live View display in M mode Ronnie B Troubleshooting and Beginner Help 2 01-14-2013 04:07 PM
Shooting with a K-01 if I hate live view on my K-5? Codazzle Pentax K-01 16 12-12-2012 07:28 PM
K-5 Live View AF Speed very good only with SMA DA 18-135mm Lens ? brosen Pentax K-5 3 10-23-2011 12:47 AM
Composing while focusing with live view magnification DanielT74 Pentax K-5 4 09-19-2011 05:02 PM
K-R trouble focusing in low light with Live View using Pentax 18-55 kit lens sportv Pentax K-r 8 01-02-2011 06:42 PM
All times are GMT -7. The time now is 03:58 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
