07-04-2013, 01:15 AM   #16
I'm only using my K30 only although i have a pretty mint Super A.. :P
Therefore,
K30 + A28/A50/A100
or
K30 + K28/K55/K105
07-04-2013, 01:19 AM - 1 Like   #17
Clavius's Avatar
I have this tiny but ideal messenger bag right now that snugly fits exactly everything I need on a walkaround:
- DA 15 ltd: leaving that at home always gives me regrets.
- DA 35 ltd: same as above. ALWAYS in the bag.
- DA 18-135: does all the work when conditions are moist/wet/dusty/etc. Often exchanged for the DA 10-17. Or my 55mm ƒ1.2. Or any of my Russian lenses.
- External mic: I sometimes end up filming and can't listen to the sound of the built-in mic.
- Cigars: A very important photografic tool for me. They help me take my time to look at the scene and think of all the possibilities.
07-04-2013, 01:20 AM   #18
Moderator PEG Judges
Kerrowdown's Avatar
For my street work recently, I run really light just a 20 mm for about 80% of my shots, the rest on the 135 mm.
07-04-2013, 01:54 AM   #19
kiwi_jono's Avatar
Depends on where I am walking around. And sometimes I dare my self to take just lens (not kit) - which is not tooooo hard as I don't have a big collection of lenses.
Most of the time I take at least my Tokina AT-X Pro 28-70 f2.6-2.8 (I find its pretty much as good as my 28mm primes @ 28). Typically also one or two of:
- A50 f1.4 (small little fantastic)
- Sigma 10-20 f3.5
- Bower 85 f1.4
07-04-2013, 02:13 AM   #20
drypenn's Avatar
If I'm just strolling, and can bring only 1 camera and lens, I always take my KX and my M28/3.5 with me. Compact, small, and cheap it can actually fit in a very small bag. If I can add another lens, I bring the tank-like, also cheap F70-210. I can walk anywhere without worrying too much, as opposed to carrying expensive glasses. I'd like to think that there are a lot of times when I'm a mere glass collector, than a photography enthusiast.
OCD sucxxx!
07-04-2013, 03:26 AM   #21
Na Horuk's Avatar
lol wow, some of you lug around quite a lot of gear. If I'm just walking, I take one prime, maybe two (with different characteristics, like one MF one AF, or one wide one long). And usually its on the K-01.
Though, I guess some of the Pentax lenses are so tiny you can easily carry even a couple of them
07-04-2013, 04:08 AM   #22
If I am going somewhere with the intentions of taking pictures of something in particular, then it isn't a "walking around" setup. In that case, I take the K7 (K5 is on the way), DA15, DA21, DA40, D FA 100. I also carry along spare batteries, SD cards, etc..
If I am just going out and want to bring a camera along for walking around, then I will choose a lens that fits where I am going. I mount that lens on the camera body, verify that the battery is charged, and that's it. Most of the time, it's either the DA15 or DA40.
07-04-2013, 06:00 AM   #23
I've settled into a "lens of the day" simple kit - with body to match. Typically a film body (MX, LX, SV) and 50 or 85 if in a Pentax mood, or Leica with 35 or 50.
07-04-2013, 06:14 AM   #24
Paleo Pete's Avatar
As with some others it depends on where I am. If I'm just close by the house, one lens will do, and that's most often the Vivitar 200mm M42 since birds are my primary target. No bag, just a spare battery in a pocket. Usually at least once every 2 or 3 days I'll switch to a 50mm and do some flower and insect shots, butterflies and dragonflies, lizards and such, and normally at least once a week I'll put together a macro rig. That's a toss up...50mm and extension tubes, usually with flash, I have 45mm of extension tubes and thinking about removing the glass from another teleconvertor to have another about 25mm, or I can use a 135mm Lentar M42 lens and any of 4 sets of extension tubes that gives me almost any combination of 10mm to something like 200mm of tubes...usually around 40-75mm. Yesterday I used 75mm and got some nice dragonfly and lizard shots. Last time out I used about 45mm.
If I take off on a drive or a road trip, I put together a bag depending on where I go. Just around town it's usually the 200mm and a 50mm, if I go out of town I take a bigger bag with 200mm, 135mm, 50mm, 28mm, mini tripod, monopod or maybe tripod, extension tubes, flash, remote...never know what I'll need on a road trip so I take a full kit. IN that case a charger for lithium batteries and one for AA too, external hard drive, just about everything...for just a drive around town, the 200mm and a 50 usually, and some extension tubes, with flash. A tripod is always in the Jeep. (I have 3 so I can leave one in the vehicle at all times.
07-04-2013, 06:56 AM   #25
JimJohnson's Avatar
QuoteOriginally posted by carrrlangas Quote
Jatrax, how´s the overlapping between DA12-24 and DA16-50? I went with DA10-17 for this fear
I'll add my bit of advice on this topic. Make sure your zooms do overlap.
I grabbed just my 18-55 and 55-300 for a wedding last year. I was a guest, not an official photographer and wanted some candid photos of family members we do not see very often. No bag, just my jacket pocket for the unused lens. It felt like the next shot really needed the lens that was in my pocket - because it was just the other side of that 55mm boundary. 'Zooming with my feet', wasn't practical. I finally gave up and used the 18-55 most of the time and cropped later.
A month after that I found my used F 35-70 to bridge the gap.
Today's WALKING (meaning lightweight) kit? DA 18-135 and DA L 55-300, extra SD card, extra battery, lens pen (rarely used in the field), monopod with quick release (doubles as a walking stick).
07-04-2013, 07:05 AM   #26
mgvh's Avatar
I'll play this game!
KITS:
#1: One lens and/or bad weather kit: K-30 + DA 18-135
#2: Travel Kits: depending on situation, #1 plus:
  • A) Sigma 10-20 OR
  • B) DAL 55-300 OR
  • C) DA 35 f2.4 or A50 f1.7 or DA 50 f1.8 OR
  • D) Tamron 90 f2.8 (if true macro needed or if 90 is right range for low-light work) OR
  • E) Tak 135 f2.5 (indoor, low-light: e.g., concert) OR
  • F) Some combination of above lenses - Most often that means #1 plus 2A and/or 2B and/or one of 2C
#3: Fun, lightweight kits:
  • One of 2C lenses OR
  • F 35-70
#4: 2 Body kits: #1 plus
  • K-x and one of 2A or 2B or 2C
As you can see, the K-30 and the DA 18-135 are an excellent pair, and I build the rest of my kit around it.
07-04-2013, 09:17 AM   #27
Docrwm's Avatar
Wait a minute! "walking around kit" sound like for casual photos, or just in case, or taking photos is not the main reason.
If you mean the kit that I have with me all the time - the K-01 + F35-70 Macro, instead of a P&S. If I am going somewhere specific then the previous post covers it.
07-04-2013, 10:22 AM   #28
rbefly's Avatar
3 Times The Fun?
Well, I do a lot of walking around, so have 3 different-sized bags, depending on how much 'stuff' I'll need. The 3rd bag holds 2 bodies, otherwise I take one body with grip, both batteries charged.
(1) Lowepro Adventura 170-. K10D, F 35-70mm Macro, Miranda 24mm f/2.8, PK-A 135 f/2.8. SD cards, CPL's.
(2) Pentax Slingbag- K-7 w/ DA 35mm f/2.4 AL, DA 16-45mm, FA 100mm f/3.5 Macro, M 50mm f/1.7, AF 360ftz, CPL's, SD cards, Luminx folding diffuser.
(3) Lowepro Pro Runner 200 AW- K-7/w DA 35mm f/2.4 AL, K10D with no lens attached. DA 16-45mm, Miranda 24mm f/2.8, FA 100m f/3.5 Macro, M85 f/2.0, A 135mm f/2.8, AF360ftz, accessories.
The Pro Runner is a fairly compact backpack, small compared to a real hiking pack but big compared to a 1-strap camera bag. It gets heavy quickly when you start packing all that glass and metal, plus some plastic. But, for two bodies ++, you can't beat it.
Ron
07-04-2013, 11:38 AM   #29
johnyates's Avatar
For me, walking around is K5 plus one manual prime. I generally use a different lens each outing, so none of them feel neglected. On any given day I would select one of the following:
Sigma 24mm 2.8
SMC Pentax 28mm 3.5
SMC Pentax 30 2.8
SMC Pentax 35 3.5
A plethora of 50's/55's too numerous to list.
55mm is the longest focal length I walk around with, otherwise I'm apt to run into camera shake problems.
07-04-2013, 12:25 PM   #30
My walking around kit requires no camera bag. It consists of my K-7 with battery grip, the DA 18-135 attached to the camera, and the DA 40 and DA 70 in their pouches attached to belt loops with carabiner clips. The belt loops are attached to pants with at least one pocket big enough to hold the 18-135 or else the 18-135 goes into a lens pouch attachable to a belt loop via carabiner clip.
bag, body, camera, da, day, kit, light, pentax help, photography, primes, stuff, travel
What's your ideal lens kit? Saxplayer1004 Pentax SLR Lens Discussion 84 12-20-2014 12:18 PM
What's In Your Bag? mcc7 Pentax K-r 40 11-28-2011 10:49 AM
What is your "Walking Around Lens?" DebLewis Pentax SLR Lens Discussion 132 07-10-2011 12:53 PM
Landscape Walking Around in a Fog PentX Girl Post Your Photos! 34 01-01-2010 06:34 PM
Walking around in my town juanraortiz Post Your Photos! 6 02-14-2009 03:28 PM
All times are GMT -7. The time now is 10:13 PM. | See also: NikonForums.com, part of our network of photo forums!
