07-04-2013, 02:51 PM   #1
K5ii will not go below 200iso
OK, I must be doing something silly. For the last two days I can not figure out why I can not set the ISO lower than 200 on my K5ii. I went in the menu to ISO AUTO Setting, and it is at 200-3200. It will not let me go lower than 200, and ofcourse I cannot go below 200 when hitting the ISO button either. I've been using it in M mode, don't know what gives?
07-04-2013, 02:56 PM   #2
You probably have highlight or shadow correction on. Those settings will limt the ISO range.
07-04-2013, 02:58 PM   #3
VisualDarkness's Avatar
Shut off highlight correction, go to the auto ISO and use the two scroll wheels to set maximum and minimum ISO. Does it work?
07-04-2013, 03:02 PM   #4
Works, Thank you!!!
07-04-2013, 03:04 PM   #5
No problem!
07-05-2013, 03:16 AM   #6
I wonder why camera doesn't disable Highlight and shadow correction by default when RAW mode is selected.
07-07-2013, 06:33 AM   #7
Finstermoor's Avatar
QuoteOriginally posted by yusuf Quote
Hiho!
Because it works also for RAW? At least that was my understandig. Am I wrong? Any link to read some more information would be much appreciated.
So long, Finster.
07-07-2013, 09:05 AM   #8
kh1234567890's Avatar
QuoteOriginally posted by Finstermoor Quote
Hiho!
So long, Finster.
Highlight correction affects RAW - basically it underexposes by up to a stop and then adjusts the brightness in software so that the brightest highlights are nearly clipped (histogram shift). Shadow correction only acts when converting to JPEG in-camera, essentially it brightens the shadows somewhat.
07-13-2013, 04:05 PM   #9
QuoteOriginally posted by kh1234567890 Quote
....(histogram shift)
As far as I know, mathematically it's not a histogram "shift".
The left border of the histogram is shifted, the right border not.
To fit in the now smaller range, the histogram gets compressed.
If highlights are still clipped, you can combine it with (-EV) and shaddow correction.
07-13-2013, 06:07 PM   #10
QuoteOriginally posted by RKKS08 Quote
All I can go by is what my K-7 does. Quick snaps (handheld so not 100% identical scene, but very close), RawDigger RAW histograms with (7313) and without (7314) highlight correction. This is what I always see.
iso, k5ii, pentax help
Pentax 18-135mm does not focus to infinity below 33mm bwDraco Pentax SLR Lens Discussion 9 07-29-2013 12:00 PM
Where will you go when P&R closes? audiobomber General Talk 102 12-16-2012 03:39 PM
How Low will the K5 Go? bonaprof Pentax K-5 & K-5 II 13 06-03-2012 08:01 PM
Why wont my K-x go below 400 ISO? slackercruster Pentax DSLR Discussion 10 05-22-2012 06:26 PM
Help! My lens will not go down to f1.7! BEENS Pentax SLR Lens Discussion 2 10-15-2010 04:37 PM
All times are GMT -7. The time now is 09:43 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
