07-05-2013, 09:32 PM   #1
Metz 58-AF TILT Problem
I have a Metz 58-AF with the latest firmware upgrade attached to a Pentax K-5 also with the latest firmware upgrade.
I noticed today that the flash display shows "TILT" regardless of the tilt angle. When the flash head is moved through the full tilt angle range, it remains displaying "TILT". Even when the head is pointing straight up.
When I rotate the flash head, the display changes to "SZOOM". When the flash head is rotated back to forward facing, it again displays "TILT".
My understanding is that "TILT" should only display when the head is tilted downward for example when taking a close-up macro.
Any thoughts?
07-05-2013, 11:22 PM   #2
tabl10s's Avatar
Do you have the manual? If not, do a reset.
07-05-2013, 11:44 PM   #3
The manual justs states that "TILT" is displayed when the flash head is tilted -7 degrees for macro. This is the only occasion it should display.
I have done a reset with no change.
I found a post where a users had problems with flash being stuck in a particular setting. In their cases, it turned out to be broken wires inside the unit.
I have emailed our Metz service rep here in Oz and will wait for a reply.
angle, display, firmware, flash, head, metz, pentax help, tilt
Warning! Read before installing new metz firmware for 58 af-1 and 58 af-2 Howdy Flashes, Lighting, and Studio 26 08-11-2013 09:27 AM
Metz 58 Af-2 vs. 48 AF-1 Alizarine Flashes, Lighting, and Studio 3 07-14-2012 08:30 PM
For Sale - Sold: Metz AF 58-1 ecwoj Sold Items 6 06-03-2012 03:30 PM
K-x with new metz 58 AF-1 wireless problem shawnrnicholas Flashes, Lighting, and Studio 5 10-29-2010 01:16 PM
All times are GMT -7. The time now is 06:21 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
