Originally posted by MJWC1 When I take a shot, the resulting image is out of alignment. That is, whatever I place in the centre ends up off centre. Usually about 10-20 percent across and a bit down. The degree of misalignment seems to vary, so while I can compensate for it when shooting, it is near impossible to get precise composition. The images look fine when framing and they are otherwise good (no problems with exposure, blurring, etc.).
This sounds similar to a problem I had with a K200D that was converted for infrared usage. To make a very long story short, as I understand it, there is a magnetic mechanism involved with influencing the position of the sensor. In my case, the entire image was shifting vertically because the magnet wouldn't "let go", so to speak.
Some PF members suggested I was being fooled by the slight crop in the K200D's viewfinder (I think it crops to something like 95%), but I confirmed what should have been in the center of the frame was moving and definitely not a crop situation. You can see what was happening to me if you read my post on a
related matter. (It's a long, long post about the crummy service I got from the guy who did the conversion.) My particular problem was due to the technician's mistake while fooling around with the camera's guts, but general handling could cause the same problem - Murphy's Law, you know!
EDIT: I forgot to mention, turning SR off did not solve my problem when I was trying to determine exactly what was going on. I didn't address that with the IR converter since there was so much wrong with the camera. I only mention it because even though the problem was related to the SR mechanism, the camera software had no influence on the function. In other words, the problem was physical and a menu setting wasn't going to help.
Reason: added point
