07-08-2013, 07:22 PM   #1
stop down coupler and t mount converter not meshing
Ok I just got in the post today an ohnar slide converter it has a t mount -k mount adapter at the base.
now that will connect to my k1000 and my k200d directly but i have a panagor auto macro converter i thought i might try with this but I can't.
the bayonet on the tmount will not go into the top of the panagor auto macro.
after several hours twiddling i think its the stop down coupler that is the problem that is in the panagor the t mount looks to have a roughly 5mm slit where the stopdown coupler is but will not turn the bayonet neither of my pentax bodies have a corresponding lever and non of my lenses have such a short slot for the stopdown coupler.
are there t mount adapters which will work with such a lever
I'm not even sure if there is any advantage to using the macro converter with the slide converter or even if focus is possible.
any suggestions on what i need to get the two bits of kit to work together?
thanks
auto, converter, coupler, lever, macro, panagor, pentax help, slide, stop, stopdown
smc pentax m 50mm 1.7 lens won't stop down pixxmania Troubleshooting and Beginner Help 5 09-11-2013 03:50 AM
Non-Pentax K bellows unit - lens won't stop down timh Troubleshooting and Beginner Help 7 04-29-2012 01:42 PM
I don't understand why stop down metering doesn't work well at higher f stops. geekette Pentax DSLR Discussion 51 06-08-2011 10:39 PM
still don't understand stop down metering dh4412 Troubleshooting and Beginner Help 5 03-17-2011 05:43 AM
K10D Stop down metering doesn't work trixtroll Pentax DSLR Discussion 2 09-23-2009 06:05 AM
All times are GMT -7. The time now is 05:56 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
