Originally posted by shaneA ...when i down load into LR4 it comes out dark , ...
It is normal for a RAW file to look flat unless you start processing it.
Lightroom already applies some automatic brightness and contrast boost in its default setting but even with these, images will not look like JPGs out of camera, say using the "bright" setting for JPG.
You can define your own "image style" and tell Lightroom to apply it to each imported image automatically by changing the default development settings. I personally don't do that as I'd like to start from a clean slate each time.
For Canikon cameras, Adobe provides emulations of JPG image styles such as "landscape", "portrait", etc., but for Pentax you can only select either "Adobe Standard" or "embedded", the latter giving you the tone curve and colour matrix as defined by Pentax.
Originally posted by Lowell Goudge Then check (assuming shooting RAW that Lightroom has the option set to use the JPEG settings for import. Tat will get you a thumbnail and first approximation to settings the same as the camera
Lightroom has no such option.
Are you talking about importing both JPG and RAW versions of the same image (if you shot both formats)?
Upon import Lightroom will always briefly show the JPG preview that is embedded in the RAW file (which will look vibrant in comparison) until it replaces it with a preview of its own rendering.
