07-09-2013, 02:23 PM   #1
Manual Focus Focal Length Setting
I have a K-5 II and was wondering what happens to the camera (if anything) if the wrong focal length is assigned upon startup. For example, I have a Rokinon 85mm f1.4, if when I turn on the camera and it asks what length the lens is and I put anything other than 85mm as the length what will the results be? Like if I put 75mm rather than 85mm? Thanks!!
07-09-2013, 02:33 PM   #2
THoog's Avatar
Nothing happens to the camera, but your image quality may suffer. If I forget to set it to 8mm for the Samyang/Rokinon fisheye, the pictures are noticeably softer. 75mm instead of 85mm may not make as much of a difference.
07-09-2013, 02:33 PM   #3
The in-body stabilization will either over or under correct for shaking, resulting in blurry images. Also, your exif will be wrong if you're trying to sort through photos by focal length
07-09-2013, 06:20 PM   #4
In addition to the SR not being quite right, the focal length recorded in the image EXIF information will not be correct.
07-09-2013, 07:54 PM   #5
Thanks folks! So as I understand it, the only thing the camera does with the information you provide it (regarding focal length) is adjust image stabilization. The EXIF will be incorrect but the image should not be affected.
07-10-2013, 02:21 AM   #6
tclausen's Avatar
QuoteOriginally posted by bunjes Quote
Almost right. The image should not be affected, other than by the SR over/under-correcting for movements..
camera, length, pentax help
K10D - Setting Shake Reduction Focal Length With Manual Focus Lenses? stewart_photo Photographic Technique 30 07-28-2016 12:52 AM
Manual Focal lens length setting stevbike Pentax DSLR Discussion 21 04-02-2013 02:38 AM
setting focal length pasojoy Troubleshooting and Beginner Help 21 12-17-2012 09:48 PM
Focal length setting lammie200 Pentax K-5 5 06-12-2012 01:51 PM
setting manual lens focal length on K20 boyscout Troubleshooting and Beginner Help 9 05-01-2009 08:55 AM
All times are GMT -7. The time now is 10:19 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
