07-09-2013, 09:02 PM   #1
Blur with Action (k200)
Hi all,
I'm new to this forum, and new to my k200, so if my question has a ridiculously obvious answer, I apologize in advance
I'm trying to take shots of exploding water balloons in a relatively brightly lit area, and try as I might, the photos have all come out blurry - the water's splash goes all smooth which is not what I wanted at all. I have fiddled with various shutter speeds and apertures in manual mode, but I have no idea what I was doing so it didn't exactly help.
So my question is: What am I doing wrong? and, Can anybody give me a shutter speed and aperture level that would work?
Thank you
07-09-2013, 09:22 PM   #2
You'll want a fast shutter speed for that (>=1/250s I'd say)
07-09-2013, 09:50 PM   #3
kiwi_jono's Avatar
Welcome!
As Adam says definitely fast shutter speed stuff. Often a fairly power flash will help too. Post some photos and I'm sure you will get some fairly specific feedback on how you can improve.
Jonathan
07-09-2013, 10:00 PM   #4
Thanks guys - I'll test it out and get back to you with the results!! *fingers crossed*
07-10-2013, 08:05 PM   #5
Kozlok's Avatar
Google's your friend on this one:
Google
07-10-2013, 08:08 PM   #6
Just1MoreDave's Avatar
This is usually something that works best by using a tripod, figuring out where the balloons will be when they explode, focusing there and turning the camera to MF so it stays focused on that spot.
The burst of light from a flash is usually faster than 1/1000 sec. at full power, faster than that at lower power levels. If the flash was providing all the light, it would act as a superfast shutter speed, even if your shutter was set to 1 second. But in your case, the relatively bright light can overpower the flash, adding too much light to the exposure. If you have a lot of test balloons, you could put the camera in Tv mode and set the fastest shutter speed the camera will allow. The camera will try to close the lens as much as possible, a very high f number. With the DA 18-55, that can go up to f38 or something. You can explode some balloons and see where the ideal combination of shutter speed and aperture is.
camera, pentax help, photography, question, shutter
blur with K-30 Sam Pentax Visitors' Center 3 06-30-2013 08:41 AM
Trouble with motion blur Crust Pentax K-01 10 02-11-2013 04:02 PM
Intolerable problem with batteries in K200 jharris9 Pentax DSLR Discussion 22 09-30-2012 04:31 PM
k200 works with only one memory card milka Troubleshooting and Beginner Help 11 08-15-2012 08:49 PM
"High speed" video of a K200 shutter in action ve2vfd General Talk 8 01-07-2009 05:11 AM
All times are GMT -7. The time now is 11:48 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
