07-10-2013, 11:33 PM   #16
I think you might have Shadow/Highlight/Vignetting/CA correction turned on. This increases processing time significantly.
You can change these via the Info button I think.
07-11-2013, 12:11 AM   #17
Pablom's Avatar
QuoteOriginally posted by SkipperRi Quote
At the end, is it possible shoot picture like this with K-7? I know how to do it with Sony NEX, but with my new Pentax...
It seems to me that if you know how to do it with the NEX there is no reason you'd have a problem with the K-7, so now I am intrigued over how you would do that with the NEX
07-11-2013, 12:37 AM   #18
SkipperRi's Avatar
QuoteOriginally posted by Giklab Quote
Ok, I'll try.
QuoteOriginally posted by Pablom Quote
On Nex this is very simple, just choose Shutter Priority. On Pentax I try this morning with Tv mode, settings 5 seconds, F8 or F5.6, ISO 100, with tripod but pictures are totaly white. Bottom line is that I must learn how Pentax K-7 working. Any help is appreciate.
07-11-2013, 12:54 AM   #19
TenZ.NL's Avatar
You can do this simply: set the camera to Av and lowest ISO possible (I think thats 100 for the K7?). Then adjust the aperture (front or back dial) until you get your desired shuttertime. You can finetune with the EV compensation.
Or set the camera to M (again with lowest ISO) and adjust aperture and shuttertime. In the viewfinder and top LCD you will see the EVcompensation (the plus and minus scale) act as a indicator for correct exposure. The more stripes to the left, the more underexposed the picture will be. More stripes to the right, the more overexposed. 0 (zero) is neutral (thats not the same as correct)
07-11-2013, 01:16 AM   #20
SkipperRi's Avatar
QuoteOriginally posted by TenZ.NL Quote
Thank you very much, I'll try this. Is it possible shoot in P mode something like that?
07-11-2013, 01:29 AM   #21
TenZ.NL's Avatar
Not sure, I (have) never use(d) P
07-11-2013, 01:34 AM   #22
SkipperRi's Avatar
Ok, thanks...
07-11-2013, 01:57 AM   #23
Get it on Matrix metering and A mode. ISO 100, and f/11. If you still don't get a slow shutter speed it's time for ND filters. If you could post the EXIF of the NEX photo that would help a lot
07-11-2013, 02:41 AM   #24
SkipperRi's Avatar
Ok, my friend, here is the picture taken with NEX5.
07-11-2013, 04:02 AM   #25
Pablom's Avatar
Looking at the water splash, that is not a 5 second exposure. In Tv mode your K-7 won't limit you on exposure duration (I think) but you can do it in P mode just scrolling the thumb wheel for Hyper program (I think you might need to enable it in the menu, it should be set as default).
07-11-2013, 04:19 AM   #26
SkipperRi's Avatar
Pablo, thank you for the advice. Tomorow morning it's next episode
07-11-2013, 06:28 AM   #27
Ok, if you go there and take a picture with the K-7 and the same settings, it should be identical. So if it's not, your K-7 is somehow not working properly.
07-11-2013, 07:13 AM   #28
JimJohnson's Avatar
Not to be a smart &$$ but I have all my camera manuals on my ipod.
Personally, I think that is simply - smart. At least for post-internet bodies, Pentax has all the manuals online in pdf form. I too have the electronic copies on my mobile devices and PCs (I have a Dropbox account, so they automatically show up on each of these devices). I rarely touch the paper copies even when they are an arm's length away for one big reason - you can search a pdf to find all related topics instead of paper flipping.
07-11-2013, 01:02 PM   #29
Lowell Goudge's Avatar
QuoteOriginally posted by JimJohnson Quote
I actually have almost all my gear in PDF format on my iPod and iPad. Pentax canada has really good scanned copies of the paper manuals etc. where I am a little limited is some legacy 3rd party stuff. I don't even know where to look for a manual for my Tmount 105/2.8 Vernon Edonar (I know it is a house brand for an old camera store, but that's it)
I also have some useful spread sheets like manual flash calculators, macro extension tube calculators etc, just for the hell of it
07-12-2013, 01:13 AM   #30
SkipperRi's Avatar
First of all, I wish thank all of you for help and great advices. Me and my Pentax getting better and better every hour. Yes, learning, practice, learning, practice, that's best way.
is one picture taken with Pentax.
Thanks one more time, and best regards!
dpi, image, k-7, nex, pentax, pentax help, quality, sony
Pentax K-30 or K-5/ii/s (Image Quality) zoolander Pentax DSLR Discussion 25 12-25-2012 11:39 AM
Pentax K-7 "Image quality falls short" ?? BethC Pentax DSLR Discussion 28 07-17-2010 01:17 PM
How close is the K20D and K-7 on image quality? justtakingpics Pentax DSLR Discussion 67 05-29-2010 03:27 PM
Question about image quality of the k-7 justtakingpics Pentax DSLR Discussion 18 05-15-2010 05:30 AM
K-7 image quality concern claude21 Pentax DSLR Discussion 31 06-26-2009 11:34 AM
All times are GMT -7. The time now is 04:34 AM. | See also: NikonForums.com, part of our network of photo forums!
