07-13-2013, 06:34 PM   #1
Problem Formating SD card
I can't get either of my cameras to format an SD card so it will work in the cameras.
What is the format that Pentax uses?
I have an older MX-4 Pic/Vid and a K110 D DSLR.
Thanks Richard
07-13-2013, 06:37 PM   #2
SpecialK's Avatar
What kind of card? Formatting in PC or camera? It the lock tab unlocked? What error message do you get?
07-13-2013, 07:05 PM   #3
QuoteOriginally posted by X-Raycer Quote
Thanks Richard
If you have an SDHC card, your K110D will need a firmware update to be able to use it:
Software Downloads : Support & Service | PENTAX RICOH IMAGING
Once you've updated, format the card in-camera and you should be all set. If you need help with the firmware update, search my recent posts (from today) and you'll see some step-by-step instructions.
07-13-2013, 09:44 PM   #4
See this thread:
https://www.pentaxforums.com/forums/general-technical-troubleshooting/231346-pentax-ist-dl.html
and let us know if that works.
07-18-2013, 01:47 AM   #5
Thanks guys. That update worked for the K-110 D.
Can't seem to find anything for the Optio MX. I know it was superseded by the MX-4. I believe I bought it in '04 or '05.
07-19-2013, 03:07 AM   #6
Maybe just try to find an old SD card on ebay for the MX?
07-19-2013, 05:09 AM   #7
I think the OP meant he/she could not find a firmware update for the Optio MX. Which is par for a point&shoot.
2GB SD (standard capacity) cards are readily available. Some older cameras will not address more than 1 GB or so of the available memory, but they should still be able to format a standard SD card regardless.
07-19-2013, 07:09 AM   #8
I assumed that the issue was that the OP used an SDHC card and as he couldn't find a new FW for the MX, the alternative would be to use an old SD cards instead for the MX.
07-19-2013, 02:56 PM   #9
Right, cheers.
Also, since he was able to update the firmware in the K110D to use SDHC cards, that means he must have the original SD card. He can re-purpose that for the MX.
07-19-2013, 03:33 PM   #10
Out of curiosity, I looked at the MX user manual. The manual has a table of SD card capacity, and the calculations they show are are based on an SD card size of just 64MB(!), which almost seems laughable.
I have an old Casio 4 MP camera of similar vintage, from about 2005 or so, for which I bought a 256MB card, and I thought that would be all I would ever need. Fast forward to about 2011 when I decided to upgrade, and ran into the same problem as you. The camera wouldn't accept the newer SDHC cards. So I wound up buying have a 2 GB SD card, even though the camera can only "see" 1GB of memory. 2 GB was the smallest SD card I could buy.
07-20-2013, 09:54 AM   #11
I'm currently using a 2GB Micro-SD card in the Optio. How much it recognizes, I have no idea, because there is no "available space" information that I can locate in the "in camera" menu.
Apparently, it does not recognize or format SDHC cards.
I have the Manual somewhere. I come across it now and again, as I'm looking for something else. I'm not very organized.
In my searches I found a chart that indicated video recording times for the Optio with various SD card sizes at a given resolution.
It included recording times for larger capacity cards, but I believe that chart is flawed / misleading.
Thanks for helping me.
Richard
07-20-2013, 12:33 PM   #12
You know, you can download your manual from the Pentax website -- here's the US version:
Downloads & Literature - PENTAX Imaging USA
And here's the MX:
Even if you have the paper manual, sometimes it is handy to have a PDF version on your mobile, or tablet, particularly for the more complicated cameras/DSLRs. (Not my original idea -- this topic comes up from time to time on the forum, and I downloaded a bunch of manuals myself in the last week.)
cameras, card, format, pentax help, sd
Problem with SD Card and *ist DL sailor1942 Troubleshooting and Beginner Help 3 03-25-2013 03:35 PM
SD card Problem pixme Troubleshooting and Beginner Help 8 07-15-2012 09:42 PM
Use of SD card that once had a problem sholtzma Troubleshooting and Beginner Help 20 06-22-2012 08:20 AM
SD card problem Rupert Troubleshooting and Beginner Help 10 04-12-2011 06:55 PM
SD Card Problem dogbear1980 Pentax DSLR Discussion 5 01-09-2010 05:29 PM
All times are GMT -7. The time now is 10:21 PM. | See also: NikonForums.com, part of our network of photo forums!
