07-14-2013, 06:10 AM   #1
No focus lock
I have a new K-30, and I bought a used 18-135 from KEH that looks to be in like-new condition. The problem is it won't lock focus on distant objects between 18 and 70mm. At 18 and beyond 70 everything's fine, but between those focal lengths I can only focus on near objects. This doesn't happen with other lenses I've tried.
Any quick adjustments I can try before I send it back?
07-14-2013, 09:40 AM   #2
If you can achieve proper focus by focusing manually, try applying a positive AF correction value (i.e. +5). If that still doesn't help, I'd just return the lens or get a new one.
07-14-2013, 06:00 PM   #3
bwDraco's Avatar
You're not alone: Pentax 18-135mm does not focus to infinity below 33mm
Apparently, the lens can't focus to infinity at the focal lengths you specified. If you go into Live View and try manually focusing at a distant object, and there is no point in the focusing range where the subject is clearly in focus (you hit the infinity stop on the focusing ring and the subject is still soft), the lens requires repair. You should exchange the lens; a technician would have to adjust the focusing helicoids inside the lens to correct this defect.
--DragonLord
07-14-2013, 07:14 PM   #4
Thanks. Back it goes.
focus, objects, pentax help
Pentax 16-50mm Won't Lock Focus A.M.92 Troubleshooting and Beginner Help 12 02-16-2015 12:36 PM
Need help with focus/exposure lock jon404 Pentax K-01 3 02-18-2013 12:40 AM
pentax kx- lock focus and re-compose mtkang Pentax DSLR Discussion 8 12-26-2011 11:47 PM
Focus and Exposure lock? BethC Pentax DSLR Discussion 10 04-15-2010 03:39 PM
Focus lock on subject raider Pentax DSLR Discussion 5 10-09-2008 11:06 AM
All times are GMT -7. The time now is 12:07 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
