07-17-2013, 04:29 PM   #1
jpzk's Avatar
The infamous "F- - -" showed up with my K5 with DA*300/4
Just as was raving about my DA*300/4 and K5 kit, the infamous F_ _ _ showed up a couple of time this late afternoon today.
This is what happened:
(fully charged battery)
1. took a few shots in TAv (as usual) and all of them were just fine, although I could "maybe" hear/feel a slight lag in the shutter when I pressed on the shutter button. "lag" as if the shutter was not quite speedy as I would nornally hear it.
I thought nothing of it at first but it did happen a couple more times. Shots were still fine.
This was at TAv 1/1600s and F4 to F5.6
I switched the camera Off and ON again. I made sure that the switches were in the proper position on both the lens and the camera. I wiggled the lens a bit to see if it was loose: nope!
2. took a few more shots and when I got ready for a subsequent shot, I saw the blinking " F_ _ _" which lsted for maybe 5 to 6 seconds, then went back normal again.
3. more shots taken ... no problem.
4. Got home, fired a few at the garden and this blinking F appeared for a second no more.
I am wondering if this is something to worry about, and maybe I should because the same happened a few years back with a Sigma zoom lens I have since sold. The buyer never had trouble with the lens and never saw the F blinking either.
Now this is a diferent story with the DA*300/4 and the K5 .... which/what is causing this behavior?
If someone can shed light on this weird behavior and offer some tips on what to check for, I would appreciate it a lot!
Cheers!
JP
07-17-2013, 04:33 PM   #2
maxfield_photo's Avatar
You might try cleaning the contacts on the lens and on the camera mount. Denatured alcohol on a Q-tip works well, just make sure that everything is turned off, might want to pull the battery just to be safe.
07-17-2013, 04:39 PM   #3
jpzk's Avatar
QuoteOriginally posted by maxfield_photo Quote
Thanks !
I will do that ...
I would be surprised if the contacts were dirty (I very seldom take this lens off of the camera) but it is nevertheless a good thing to do.
Cheers!
JP
07-17-2013, 05:32 PM   #4
c.a.m's Avatar
Our weather is very hot this week: 34 C in Ottawa, low 30's in Québec? Perhaps it was a case of the camera overheating, although the K-5 is rated to +40C.
- Craig
07-17-2013, 05:43 PM   #5
jpzk's Avatar
QuoteOriginally posted by c.a.m Quote
- Craig
Thanks Craig.
It wasn't hot at all here during late afternoon ... I would think about 25C or less with a good wind.
So, I assume this was not an overheating matter.
Only thing: lots of humidity after a shower at the end of the afternoon (4-ish) and the sun coming out after ... steamy but not "fiery" hot.
JP
07-17-2013, 06:17 PM   #6
scratchpaddy's Avatar
For the record, it was 42°C when I was shooting on the 4th of July, and my K-5 did not complain.
QuoteOriginally posted by jpzk Quote
"F- - -"
That's what I say when I get somewhere, turn the camera on, and it says, "No card in camera."
07-18-2013, 03:00 PM   #7
jpzk's Avatar
QuoteOriginally posted by scratchpaddy Quote
That's what came up in my head as a response when I saw this blinking "whatever".
Update: I thouroughly cleaned the lens and contacts, went out for a few shots: no problem today.
So that could well be what it was and I hope that is all there is to it.
Cheers !
JP
08-14-2013, 06:32 AM   #8
I had this problem using a Simga 28-70 on the weekend
I was shooting at a drag meet. So didn't notice at first, but then when I was reviewing the shots several dark images where present.
After a while I notice the F-- and noticed if I moved the base of the lens against the camera the F-- changed to the proper aperture.
I wiped the contacts on both the camera and lens, but still had the same problem the next day.
I used my primes and had no problems. Is this a big heavy lens problem or a contact problem?
Cheers
Colin
08-14-2013, 08:40 PM   #9
I had this problem with an older screw-drive Sigma 105 EX DG macro on Tuesday evening when I was using this lens at a gig. After mounting the Sigma, for some reason the camera started intermittently asking for focal length, and F-- would also flash. AF and exposure also went wonky. I kept shooting but half the shots showed 85mm focal length in the EXIF and the other half 105mm.
I can only conclude that I didn't mount the lens properly. I will clean the contacts on the lens and mount and next time I will pay more attention when mounting this lens. Unfortunately it meant I missed some nice shots.
08-15-2013, 02:50 PM   #10
jpzk's Avatar
QuoteOriginally posted by colinmiller18 Quote
Cheers
Colin
Weird that Sigma lenses show more often with this F - - - thing.
I had similar problems with a brand new Sigma 100-300/4 a while back and even Sigma couldn't figure out what the matter was.
Anyway, I sold it but the owner never had problems with it ... go figure!
JP
08-15-2013, 04:36 PM   #11
psychdoc's Avatar
I have seen this with my K5 and lenses two or three times in the last few years, I just released the lens and put it back on again because someone said on this forum that it can happen with a loose contact between the camera and lens. Not sure if that is true or not and why if true. But I have not changed my lenses or camera and it has worked fine...
behavior, camera, couple, da*300/4, k5, lens, pentax help, shots, shutter, tav
Macro Just the 100mm Pentax WR macro and K5 flash "around the home" charliezap Post Your Photos! 14 08-10-2012 05:48 AM
Nature More "back yarding" with the Pentax 55-300 charliezap Post Your Photos! 8 02-11-2012 06:40 PM
Misc "The Party"Act1-"While my guitar gently weeps" charliezap Post Your Photos! 9 01-17-2012 11:12 AM
Is the Pentax DA* 55mm f/1.4 a great "walk-around" optic with the K-5 in wet environs stevelink Pentax SLR Lens Discussion 19 10-05-2011 11:50 PM
K5 mirror "stuck up" or "flop"? jpzk Pentax K-5 6 09-09-2011 07:20 PM
All times are GMT -7. The time now is 05:14 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
