07-19-2013, 05:02 AM   #1
6x7 TTL without the lens attached
Hello,
does the 6x7 TTL metered prism work without the lens attached (I mean if is the needle inside viewfinder moving)? I just acquired a Pentax 6x7 body with a TTL prism and the needle is not moving. I have a fresh battery in it and the body is working great. I just can't test it with the lens right now.
Thanks.
07-19-2013, 08:38 AM   #2
No. Just tried mine. Meter needle moves with the lens attached - removed the lens, turned the meter on and the needle stays put at the bottom.
With no lens the aperture sensing pot is at the extreme position so the needle doesn't move. Same thing I expect if you attach the prism with a lens in place and break the meter chain at the front of the focusing screen.
07-19-2013, 09:38 AM   #3
Thank you, I thought so, but I was not sure!
body, camera, lens, needle, pentax help, photography, prism, ttl
6X7 TTL Prism -is speed dial adapter ring needed? germar Pentax Medium Format 12 04-20-2016 07:34 AM
6x7 without MLU? keyofnight Pentax Medium Format 13 10-05-2012 06:06 PM
For Sale - Sold: COLLECTOR QUALITY Pentax 6x7 MLU TTL kit cheekygeek Sold Items 2 10-16-2011 06:29 PM
Pentax 6x7 TTL Prism and non metered. carsonbm Pentax Medium Format 9 04-26-2011 03:04 PM
Pentax 6x7 TTL Prism? carsonbm Pentax Medium Format 3 11-07-2010 05:50 AM
All times are GMT -7. The time now is 12:13 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
