Originally posted by Kozlok The programming of the auto setting assumes you want to correctly expose the background, so it meters out a slow shutter speed. When using flash, you really need to take charge and go to manual. Think about it this way, if you are using flash with people up close, and the scenery in the distance, the flash can not illuminate the scenery, so the shutter speed must remain relatively slow. If the background is relatively close, you will want fast shutter speed because the scenery wil be lit by the flash, and the faster shutter improves motion blur. The camera can't tell the difference, so you must take over control.
The truth is that onboard flash is almost useless, especially in green mode. Look over at strobist.blogspot.com for a trove of info on flashes. My main use for on board flash is as a trigger for a real flash.
Kozloc. I believe you are spot on! That explains it. I usually don't use Auto for anything unless I hand over the camera to my wife or just want a quick snapshot. Your comments make perfect sense.
Jim, I typically use my 30 year old flash also. Same one I've used for the old Pentax SLR 35mm film camera and K10D
I guess I was just checking to see if there was anything wrong with the camera. S my recommendation for others wanting to just do some snapshots is to use the P mode and set the speed to 1/100. Tried it on several quick shots and the pictures are great. And not blurry.
Thanks everyone!
