07-22-2013, 02:10 PM   #1
AF Spot Setting problem: X-5
Hello Fellow Pentax owners,
I have a new X-5 and I'm having difficulties with the menu.
It seems that some setting are "not available".
I need to set my AuoFocus to Spot and I am following
the instructions according to the User Manual (P91 on .Pdf / numbered 89 in manual).
The Autofocus Focusing area settings in the menu (once I enter the AF setting menu)
does not have the SPOT option to set. Only Focusing Area (fixed to Multiple, no option to change to spot) Auto Macro and Focus assist features appear. I can change the latter two, but not the Focusing Area - it seems to be fixed to Multiple.
The Focus Mode Area Selection "grid" [25 points] is blanked out as well, so I cannot select that to set either.
Any ideas? Help would be appreciated. I want to be sure first, before returning it for replacement.
Not sure if it's faulty, Maybe I'm not doing something right to activate all the functions on the menu.
I've reset everything to default and it still didn't work.
Thanks!
Jack
07-22-2013, 03:43 PM   #2
Hi
I don't have an X-5, but I know that on the K-5 you cannot set a lot of the options when the mode dial is on Green (Auto Pict) Mode.
Have you tried changing to M for Manual or P Mode and then check if you can adjust to centre AF? Maybe give that a go?
Cheers
Dean
07-22-2013, 11:34 PM   #3
Cheers, Dean.
It was as simple as that.
Just moved from Green to M or P and all menu options were activated.
Appreciate it, mate!
Jack
07-23-2013, 05:58 AM   #4
QuoteOriginally posted by JackinDublin Quote
Cheers, Dean.
Jack
Hey Jack
Always nice when it's an easy answer, glad that was it.
Cheers
Dean
af, change, focus, menu, option, pentax help, spot, x-5
X-5 purple spot L Harrison Visitors' Center 2 01-22-2013 09:51 AM
Spot AF vs Select AF szmatefy Pentax K-30 & K-50 3 01-20-2013 12:20 AM
For Sale - Sold: Tokina AF 24-200mm f3.5-5.6 SD AT-X 242AF *LN* cheekygeek Sold Items 3 12-10-2011 01:38 PM
Black Spot Problem - NEW K-X Blue Jay Pentax DSLR Discussion 28 05-07-2010 06:21 PM
Problem with setting ISO on new White K-x whbroker Pentax DSLR Discussion 5 04-15-2010 10:03 AM
All times are GMT -7. The time now is 06:31 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
