07-23-2013, 09:04 PM   #1
Pentax K-5 and Yongnuo 560 III
Hello everyone,
I have a k-5 and would like to connect it to a Yongnuo 560 III (wired). I'm not sure what type of sync cable to buy. Can someone point me in the right direction please?
Thanks
Joe
07-24-2013, 04:29 AM   #2
You could use a pc to pc cable to connect the K-5's flash sync port (the plug right below the popup flash button) to the speedlite. But since the YN-560 III has a wireless receiver in it, I don't know why you wouldn't get an RF-602 or 603 transmitter instead. PC cables are a real pain in the a** to use. They fall out easily, bend when stepped on, can be tripped over, and they're not all that cheap.
Just my $0.02.
07-24-2013, 04:38 AM   #3
p38arover's Avatar
Can we assume you don't want to use it mounted on the K-5 hotshoe?
07-24-2013, 05:20 AM   #4
Thank you for responding.
Ale_guy, I will be using the camera and flash in a photobooth setup where the equipment will be static. The camera will be in an enclosed box and the flash/umbrella setup will be mounted above the box. I would like a wire solution for this so that I don't have to worry about batteries being drained in the transmitters.
p38arover, I did see that but i don't really see the pro to using a hotshoe adapter if I'm not using a P-TTL flash (I could be wrong on that).
I was over whelmed when doing a simple search online for PC sync cords and I saw male/female, screw type PC connectors, 3.5mm, 2.5mm mono jack...
Thanks
Joe
07-24-2013, 08:58 AM   #5
crewl1's Avatar
The K-5 sync port uses universal PC cable style like this>
I don't know what is on the Yongnuo side.
07-24-2013, 09:08 AM   #6
crewl1's Avatar
The screw version of the above looks like this, you can also use it but it takes a few moments longer to attach/remove if you want to use the screw function. (Ignore the phono plug)
07-24-2013, 12:47 PM   #7
Thank you sir!
camera, iii, k-5, pentax help, pentax k-5, photography, yongnuo
Yongnuo YN-560 III Flash 2.4GHz worth buying or not? siamthai Pentax K-5 & K-5 II 98 04-08-2015 09:28 AM
For Sale - Sold: Pentax TR Powerpack III and K-AC50 A/C adapter for K-7, K-5, K5II arm_jstp Sold Items 2 01-23-2013 08:29 AM
Yongnuo 560 II jeztastic Flashes, Lighting, and Studio 6 03-07-2012 04:13 PM
yongnuo YN-560 flash for k-x mtkang Flashes, Lighting, and Studio 25 01-03-2012 11:22 AM
Pentax 540 and Yongnuo 560 - if they flash together? pich Flashes, Lighting, and Studio 3 10-29-2011 04:49 AM
All times are GMT -7. The time now is 10:05 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
