07-29-2013, 05:22 AM   #1
Catch in Focus on K-30 with...
Screwmount lenses like the ones in my signature.
All have the "A" settings but when I go to turn on CiF it does nothing, just let's me know like usual when something is in focus. I think it might be operator's problem in this one and wanted to ask for the whole procedure. What I need to turn on or off in order to at least try this feature in my camera.
07-29-2013, 05:33 AM   #2
boriscleto's Avatar
The A setting on a M42 lens has nothing to do with CiF, in fact a M42 lens set to A will always be wide open (there is nothing in a K-mount camera to stop it down).
The Takumars you have are not wide enough to short the correct pin for CiF. You will have to short the pin with some metallic tape or foil. There are instructions somewhere in the forums.
07-29-2013, 05:43 AM   #3
So it's a pin that enables the body to do this. I should try it with my kit lens? I thought I did and it didn't fire either, then again my kit lens is the crappiest of them all the 18-55mm non WR.
Actually I understand what you are saying about the "A" in terms of the body, but if I take it of the "A" then the lens will open wide and I can only go to other apertures manually when it's on the "A" setting. Am I understanding correctly in saying you are talking about treating the "A" as Automatic being the body controlling it?
07-29-2013, 06:17 AM   #4
boriscleto's Avatar
QuoteOriginally posted by BigJPR Quote
The kit lens can't do CiF because it is an AF lens and lacks a MF switch. (For CiF to work with an AF lens the lens has to be able to switch to MF only. The MF setting on the body turns off CiF mode.)
On a M42 lens it is in 'A' or Auto when 'M' or Man. is covered. It is in Auto when Man. is covered.
07-29-2013, 08:54 AM   #5
All this time and now I get it. I got the K30 since February and haven't even attempted to us it, just got curious as of late. Thanks boriscleto for your help.
camera, focus, pentax help, photography
Catch in focus - K-5 with Asahi 50mm f1.4 manual lens??? vmahodaya Pentax K-5 & K-5 II 14 04-10-2015 10:03 PM
Which lenses support catch-in-focus on K-r? gifthorse Pentax K-r 9 12-08-2011 07:40 PM
Problem with catch in focus merdenoms Pentax DSLR Discussion 8 10-14-2011 09:13 AM
Catch-in-Focus defect on K-x Marlboroman Pentax DSLR Discussion 16 03-09-2011 12:15 AM
Catch-in Focus questin on K-x ptx101 Troubleshooting and Beginner Help 6 10-10-2010 12:38 PM
All times are GMT -7. The time now is 10:35 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
