Originally posted by DBart
I dropped my camera and it cracked the LCD screen so that 2/3 of the screen is not viewable. have you replace the screen in your K10D yet and if so , how did it work. If you had it replaced, what was the cost of having it replaced and do you recommend someplace to send it?
Thanks for the help
I ultimately didn't have it replaced. When I took it to my local shop for someone to actually look at it as opposed to describing it over the phone. The moisture in the LCD cleared up after a while. The problem was a small amount of rust.
