Originally posted by GBNeil I think the adapter was threaded on the lens correctly but probably the adapter/lens not properly onto the camera. Either way I have a problem. I'll be so relieved if I get this problem resolved I might even consider the exorbidant cost of genuine Pentax Adapters in future.
See my post above, the only problem is that to use it the way you want, you have to remove that spring and screw from the adapter first. But really, just try to align it again with the red dot in the correct place, pull it outward until it locks firmly, then start unscrewing it slowly with steadily increasing pressure, it should release like a tightly screwed on bottle cap, all of a sudden, just some constantly supplied pressure in the right direction, and it should work
