08-13-2013, 09:00 PM   #1
same camera and lens
i have shot with 2 of the same cameras with the same lens, both in auto. How come one is way warmer looking then the other?
08-13-2013, 09:04 PM   #2
It's set to auto, so the camera has to guess at the white balance. If your framing is slightly changed, the algorithms in the camera will interpret the scene differently and change the white balance accordingly.
08-13-2013, 09:04 PM   #3
At the same time? Was the lighting fluorescent?
08-13-2013, 09:26 PM   #4
same time. checked all the settings. is there one i could have missed?
08-13-2013, 09:28 PM   #5
the lighting is overhead incadecent. may actually be one of those cfl bulbs. just doing some camera testing. i swapped lenses, and still one is shooting "greener" while one is "redder"
08-13-2013, 09:29 PM   #6
QuoteOriginally posted by adpo Quote
i have shot multiple images back and forth, and the one is continuously warmer in color than the other
08-13-2013, 09:54 PM   #7
Can you post some examples with EXIF intact?
08-14-2013, 06:18 AM   #8
QuoteOriginally posted by elliott Quote
EXIF??---- sorry I'-m not sure what that is. I'm newish to digital.
08-14-2013, 09:46 AM   #9
QuoteOriginally posted by pixxie Quote
All of the metadata the camera stores with the image, it tells the settings that were used for the image. As long as it is uploaded straight from the camera it should be still there, some editing programs strip it.
08-14-2013, 01:32 PM   #10
Moderator PEG Judges
Kerrowdown's Avatar
It could be as simple as manufacturing tolerances, causing the slight variations in the camera sensors and hence the way that they record images.
If colour is critical, I use the X-Rite ColorChecker Passport, which saves so much time in PP later.
08-14-2013, 04:38 PM   #11
JimJohnson's Avatar
Pixxie- It sounds like you are saving your images as jpeg images rather than RAW. RAW images are pretty much 'as is' as seen by the sensor, and jpeg images are created by the camera's built-in computer from RAW data.
However, your camera's jpeg software is adjustable. There are several pre-programmed variations and the ability to build a custom jpeg rendition. If there is a noticeable difference between two cameras used right next to each other with the same lens and other settings, I would look at the jpeg rendition settings. You don't tell us which camera body you are using, but you can reach the jpeg rendition settings on most via the INFO button.
Tell us what you find.
08-14-2013, 05:52 PM   #12
im using a kx.
08-14-2013, 06:04 PM   #13
JimJohnson's Avatar
im using a kx.
Press the INFO button and look at how your jpeg settings are on each camera.
08-14-2013, 06:08 PM   #14
QuoteOriginally posted by JimJohnson Quote
they are the same :/
08-14-2013, 06:14 PM   #15
i manual wb them both to a white paper, and still one is shooting warmer
lens, pentax help
Use on camera flash and remote trigger at the same time nu12ul Flashes, Lighting, and Studio 12 10-31-2012 04:53 PM
APS-C vs Full frame background blurriness on same lens same subject Enkhbayar Photographic Technique 30 02-07-2012 03:03 AM
is this one and the same lens? lancer3397 Pentax SLR Lens Discussion 14 08-26-2011 02:57 PM
Nature Same sun - Same lens - Different decade pacerr Post Your Photos! 4 08-04-2010 02:14 PM
85mm vs. 50mm which is which (same subject, same aperture, same magnification) stevebrot Photographic Technique 50 07-01-2008 09:49 AM
All times are GMT -7. The time now is 01:39 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
