08-18-2013, 07:39 AM   #1
k30 liveview mirror lock up failure
Hello,
I want to share here a problem I got yesterday. I did push the "live view" button on my k30 for a shot and the typical noise of the mirror getting up occurred. Yet it apparently did not complete and the screen remained black (I could nevertheless see it was on) and inside the camera there was a weak motor-like noise. As there was nothing that could be done from the command buttons (Including on/off who had no effect), I removed the battery.
When I put the battery back and switched the start button to "on", everything went back as normal and I did not reproduce the problem. I suspect that a little dust did block the mirror from completing it's move. Since then I hear a strange metallic noise when moving the camera sideways. I don't know though if it's only the usual SR noise and me freaking because of what happened .
Thanks for your input if you encountered something like this problem. Maybe it's related with the random exposure problems that have been reported on this forum?
08-19-2013, 05:47 AM   #2
JimJohnson's Avatar
QuoteOriginally posted by LDPDC Quote
Hello,
Unless you have been using your camera in unusually dusty conditions, I suspect a weak battery. Live View consumes a lot of power. Turning the camera off and temporarily removing the battery allowed it to recover enough to cycle the mirror. Unless it is unusually loud, the noise you describe sounds like the sensor moving freely within its SR region when the camera is off. Normal.
battery, button, camera, k30, mirror, noise, pentax help
Mirror Lock-up Wingincamera Pentax K-5 4 06-28-2013 03:26 PM
Mirror lock-up with 2-second delay bpv_UW Pentax K-5 4 02-14-2013 02:22 PM
Time lapse shooting with mirror lock-up? jpyykonen Pentax DSLR Discussion 7 01-31-2013 09:26 AM
Mirror lock-up gorski Pentax K-30 & K-50 3 07-23-2012 04:04 PM
Pentax K30 Mirror Lock Up. Chuck-B&H Ask B&H Photo! 1 06-04-2012 02:41 PM
All times are GMT -7. The time now is 01:48 AM. | See also: NikonForums.com, part of our network of photo forums!
