Hoping someone can help with my exposure metering problems on my K200D with M lens, using the built-in flash. When I am in low light indoors, when I use the flash with a large aperture, I often get completely blown out photos.
Without flash, I am following Adam's procedure here:
https://www.pentaxforums.com/forums/pentax-lens-articles/110657-how-use-meter...k-x-k-7-a.html
So I set the camera on M, set the aperture manually using the aperture ring on the lens, press the green button to meter, and then take the picture. This seems to work fine.
With flash, using the same procedure, I get completely blown out photos at large apertures. It is as if the camera does not set the shutter speed properly with the flash. There must be some setting I am missing.. Looking at the manual, there is a sentence that reads "the built-in flash fully discharges for lenses without a function to set aperture lens ring to A". This sounds like it addresses my situation, but it also implies that the flash can "partially" discharge? So related question is - does the flash vary in intensity depending on exposure needs? And then does this mean that you basically cannot use the flash with M lenses? Or that there is a set aperture or shutter speed that syncs with the flash?
Reason: typos
