Originally posted by boriscleto ...Post some pics of whatever you want identified. We can try to identify it, if we can't maybe someone at The MFLenses forum can.
OK; I just took some shots of my Dad's old screw mount lenses out on the porch with my K100D. After much trial & error (mostly error) I discovered that when set on the "Tv" notch on the program dial (lens still set on "M") I seemed to be getting some decent exposures for a change.
Here's some of them in their nifty leather cases:
Lo and behold, I now have not one but TWO wide angle Spiratone lenses:
Another view:
What is the functional difference between these lenses? Which is the better all round lens to use on my 100D (which cuts picture area considerably due to extended focal length of the body)? Can I flip one of them to use for super macro if I want to?
There is one 135mm lens which does not fit on to the Vivitar tele converter ring; it goes in about 3/4 turn and jams. Same dia. but different pitch, it seems.
Here it is with an old "Ricoh" photoelectric exposure meter:
What does the red "Tc" mean? If this lens will not fit my Pentax adapter I will probably put it up for sale. Any idea what I should start asking for it? It might have been for one of Dad's Leicas or even the Zenit for all I know.... which isn't much! (That's why I'm here!)
Now for the heavy artillery - the long 400mm telephoto:
The tele ring does thread on to this one, so I have high hopes of being able to crank it on to the 100D. It looks like a pretty decent glass... is it?
The adapter mount should be here in a couple of days, and I'm chomping at the proverbial bit to see how this old glass works on the digital body. Thanks for your feedback on that; I'm now even more glad that I went with the PENTAX OE.
