08-22-2013, 07:58 PM   #1
yongnuo 560 III with K5 IIs
Hi,
I am trying the Yongnuo 560 III with K5 IIs, on camera, it only fires in Av I am using SMC A 35-70 mm lens in the A position.
Out of camera flash fires with the pop up flash in any camera mode.
The wireless mode does not seem to work with wireless from the camera, I might have to get the wireless transmiters.
Anybody here has experienced the same with this setup?
Also tried with the MX-1 and fires in slave mode with the MX-1 pop up flash.
Thanks for your help
08-22-2013, 08:33 PM   #2
It only works in wireless mode with the RF-602 or RF-603 transmitters from Yongnuo. I have heard the RF-603N works great with Pentax.
The shutter speed must be 1/180 or slower for your camera to trigger the flash, this is likely why you were having problems on camera. The same limitation applies if you are using RF triggers.
08-22-2013, 09:23 PM   #3
Thanks! I will try that, do those wireless triggers transmit TTL too or is it another model?
08-22-2013, 09:36 PM   #4
QuoteOriginally posted by dltorre Quote
The YN-560 can't receive any TTL signals, so it doesn't matter in this case, but the RF-602 and RF603 are manual only. They don't currently make a P-TTL model for Pentax.
08-22-2013, 10:50 PM   #5
Thanks for all the info, I did get it to work on M now lowering the shutter speed to 1/160, Thanks!
08-25-2013, 06:59 PM   #6
I was just looking at the manual for this flash today and your flash is fully manual except that it supports wireless and optical trigger. There are a couple reviews of the predecessor model (560 II) here:
Yongnuo YN560II reviews - Pentax Camera Accessory Review Database
M-mode or X-mode is the way to go.
camera, fires, flash, iii, mode, mx-1, pentax help, pop, yongnuo
Yongnuo YN-560 III Flash 2.4GHz worth buying or not? siamthai Pentax K-5 98 04-08-2015 09:28 AM
Pentax K-5 and Yongnuo 560 III wmich Troubleshooting and Beginner Help 6 07-24-2013 12:47 PM
What's up with my new Yongnuo Speedlite YN 560-II...no hotshoe mount? Edgar_in_Indy Flashes, Lighting, and Studio 13 04-16-2013 11:49 AM
Yongnuo 560 II jeztastic Flashes, Lighting, and Studio 6 03-07-2012 04:13 PM
Yongnuo 560 with K200d iClick Pentax DSLR Discussion 2 06-17-2011 08:57 PM
All times are GMT -7. The time now is 09:37 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
