Originally posted by carlosodze is there a huge diference shooting hand-held and with a monopod?
Yes. Any camera support (tripod or monopod) that touches the ground or something solid will result in sharper photos, even with fast shutter speeds (and of course, with slower shutter speeds). Since you can't always take a tripod or monopod with you,
read this to make your "handheld" shots even better (and note that he uses solid objects for support).
Originally posted by carlosodze can you recommend a good and affordable tripod/monopod?
For ones that convert from tripod to monpod, look for
Benro "Travel Angel" and
Sirui "N-series" or
"M-Series" tripods. You can find them on eBay for around $200 for the aluminum versions. The ones linked are very good, and even have decent ball heads included (in some cases), and aluminum is not much heavier (but a lot cheaper) than carbon-fiber. For tripods, consider the size of the tripod when closed, as well as when fully extended... if you are really tall, this can make a difference!
