08-26-2013, 07:30 AM   #1
Repair of Carl Zeiss Jena DDR 135mm F3.5
Hi
I have a CZ Jena DDR 135mm F3.5 which has developed an issues. The aperture control ring stopped working for some reason so I took it apart and managed to line up the control lever inside with the switch and got it working again. However it has now stopped working again and the small control lever inside has come off the lens housing.
I can't figure out where it attaches and whether it screwed on or whether it was molded plastic. I hope anyone who has repaired one of these lenses can understand my no very technical explanation.
Can anyone give me some idea of how to go about repairing this lens as until this happened the lens was in perfect working order.
Thanks
08-26-2013, 08:30 AM   #2
Jean Poitiers's Avatar
Bonjour,
Could you include some images ?
Is yours like mine which I have opened and repaired several times ... J
08-26-2013, 07:07 PM   #3
Erdž's Avatar
QuoteOriginally posted by fizzyvimto Quote
When I disassembled mine, the info provided at Servicing The CZJ 135mm f/3.5 Lens was invaluable.
Hopefully it can help you too.
08-28-2013, 04:48 PM   #4
Thanks for your replies. I have the type of lens that is in the link Erdž has posted, not the zebra one. I'm not sure if they're the same inside or whether they are completely different. Erdž do you know if the top part of the lens, with the aperture ring can be taken apart? I heard a rattling when I took it off and a small screw fell out. The aperture lever which has fallen off has a small screw hole so I assume it has worked loose and come off. However I can't see any way to fix it back on and can't see any way of disassembling this part of the lens.
08-28-2013, 05:09 PM   #5
Hi
I undid one of the screws on the rear of the lens and managed to take the rear part apart. However now I have a small screw, a spring and a silver rod. I have no idea where these have come from as they fell out when i opened it up.
Here are some pictures:
From left are the aperture lever, main rear assembly mounting screws, small screw for mounting aperture lever (assumed), small screw and spring and silver rod.
Thanks for anyone who can help me make sense of this.
135mm, carl zeiss jena, control, ddr, f3.5, lens, lever, pentax help
For Sale - Sold: Pentax SMC 85mm F1.8 - carl zeiss DDR Jena 135mm F3.5 (M42) loikos Sold Items 2 11-14-2012 08:32 AM
Carl Zeiss Jena vs Pentax M @ 135mm f3.5, which one has the better IQ? HoBykoYan Pentax SLR Lens Discussion 26 02-26-2012 12:16 AM
Interested to know about Carl Zeiss Jena 35-70 f3.5-4.5 Damon Troubleshooting and Beginner Help 4 02-06-2012 11:44 PM
For Sale - Sold: Carl Zeiss Jena DDR Tessar 50mm F2.8 alanjoke Sold Items 6 08-26-2011 06:17 AM
Carl Zeiss Jena DDR Sonnar 2.8/180 ? vievetrick Pentax SLR Lens Discussion 11 11-27-2007 10:19 AM
All times are GMT -7. The time now is 07:04 AM. | See also: NikonForums.com, part of our network of photo forums!
