08-26-2013, 11:26 AM   #1
Auto/Man Switch screw
Hi Folks,
Just acquired a nice Super Takumar 55mm F2 & in the process of cleaning it the Auto/Man Switch fell out. I managed to find 1 of the tiny screws, so the first question is:
Any idea where I could a replacement screw?
Once I get that, we'll talk about repairing it.
Stupid question but how can I tell which mode it's in now - Man or Auto?
Thanks for any help!
SAMSUNG PL210, PL211 / VLUU PL210, PL21  Photo
08-26-2013, 11:30 AM   #2
If the aperture blades open and close when you turn the aperture ring, it is in manual. If they stay open all the time until you press in the little pin, it is in auto.
08-26-2013, 02:24 PM   #3
kcobain1992's Avatar
Any possibility that the second screw is still inside the lens?
08-26-2013, 02:34 PM   #4
I had the same problem and the second screw was inside the lens still...gentle shake and hope for a rattle
Cheers
Dean
08-26-2013, 02:43 PM   #5
Not a Number's Avatar
Pan Head Machine Screws - Phillips - Stainless - Micro Fasteners
08-27-2013, 01:38 AM   #6
Brilliant! I had tried shaking it a bit (hmmmm) but it must have moved as I could hear it's faint, pleading cries for help.
I'm not going to sit around listening to that - I'll have a snork around the site but if anyone knows a thread that'll help?
Thanks!
08-27-2013, 03:30 AM - 1 Like   #7
Well, I am going to link to my own tutorial, although it is not the exact same process, the disassembly is the same. Unfortunately, if I look closely at the picture from step 8, I think you will need to disassemble the whole aperture closing assembly (screws + levers + springs) in order to access that switch, which may be a pain, depending on your skills.
08-27-2013, 04:16 AM   #8
QuoteOriginally posted by kcobain1992 Quote
I found your tutorial too - excellent. Unfortunately my experience is non existent & it does seem like I have to dismantle everything. On the positive side I would definitely learn a huge amount. Oh dear, I can also hear a little voice saying v. faintly 'No, not ebay again'
08-27-2013, 06:38 AM   #9
Contact Eric and ask for an estimate. You may as well have the lens CLAed while you are at it.
Home
08-27-2013, 06:49 AM   #10
Home
Thanks for that, we need an Eric in the UK!
What on earth is is CLAing though?
08-27-2013, 07:40 AM   #11
I'll just add 'Beware the little springs!'
I have taken apart a few Takumars to clean fungus etc., generally no problems.
However, when I tried to fix my Auto/Man switch I removed the aperture arm that holds those couple of little springs in place...and that was it...no amount of swearing and fiddling could get them back in place. I ended up taking the pieces to Camera Electric in Perth and they were able to re-assemble the spring mechanism. Right tools for the job and more experience than me...
Anyway, good luck with it...
Cheers
Dean
08-27-2013, 08:15 AM   #12
CLA = Clean Lubricate Adjust
I'm sure there is someone in the UK that is the equivalent of Eric
08-27-2013, 01:09 PM   #13
Harrow Technical?
But anyway, I'd rather get another copy and use this one on a film camera until I get enough experience and the proper tools, and only then attempt to repair it myself.
08-27-2013, 02:23 PM   #14
QuoteOriginally posted by Dean Bradshaw Quote
Cheers
Dean
And did you manage to fix the lens yourself? And if so how tricky was it and how much experience did you have?
I'd like to have a go if I've a reasonable chance of success. After all the lens is hardly unique.
08-27-2013, 03:44 PM   #15
QuoteOriginally posted by GBNeil Quote
See my response 'Beware the little springs'...
As you said, the lens isn't super rare or overly expensive (but great fun and great quality), so opening it up and having a look is a fun learning experience.
I'm far from experienced, and as above, the little springs defeated me...other than that if you keep the parts laid out in order it'll go back together easily enough. A few tricky little screws and resetting the infinity focus are the challenges.
There are a few 'How to' threads on this site, and google...but look for the 50 1.4, as that seems to be the one most repaired, and really very similar.
Cheers
Dean
auto/man, pentax help, question, screw, switch
Screw-drive Auto-focus Noise Source RobA_Oz Pentax SLR Lens Discussion 5 08-19-2013 04:35 PM
Lenses without Auto/Manual Aperture switch toukan Troubleshooting and Beginner Help 6 07-11-2013 01:18 AM
35mm zebra Flektogon - no auto switch problem les24preludes Pentax SLR Lens Discussion 7 11-18-2012 02:36 PM
K-x auto focus switch smokeydan Pentax DSLR Discussion 4 03-08-2010 08:50 PM
auto/man switch question BernardMarx Pentax Film SLR Discussion 15 06-15-2009 12:11 PM
All times are GMT -7. The time now is 07:10 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
