Originally posted by Keith.A Spots on my pictures. it is not my lens(s).
Example pictures might help. Most common issue is dust spots on the sensor, which may need wet cleaned. But hard to say without seeing the problem.
Originally posted by Keith.A My question is if there is pixal damage can it be fixed?
Not sure what you mean (pictures again will help) but if you mean actual 'bad' pixels, then no those cannot be fixed. In more recent cameras there is an option to map out bad pixels but I've no idea about K200.
Originally posted by Keith.A Would it be worth my while getting it repaired or would I be better off investing in another camera?
Only you can answer that, knowing your budget and circumstances. If it was me, with a 5 year old camera, I would look seriously at the k-30 or k-50. But that's just me.
If it is just dust spots those can be cleaned away for minimal cost. The flash is more problematic and unless someone else here has experience with that problem I will assume it will need to go away for repairs. Cost of repair? No idea, but you might be able to get an estimate from a repair shop.
