08-30-2013, 06:12 PM   #1
Problems with setting the f-values (Pentax X-5)
Hello!
My name is Diana, I'm from Colombia and just a week ago I bought a Pentax X-5. When I am in Manual mode, there is no way I can set a fine tune of the f-value, it just jumps from two extreme values, for example, 3.1 to 9.7 or 4 to 12. If I change the mode, the numbers automatically set to different values, (especially when I use the long zoom) then I go back to M mode and it jumps from a lower to a higher value. Just those extreme numbers, from 4 to 12, 6 to 15 or 18!. I am taking photography lessons and it is somehow frustrating for me that I haven't been able to experiment with the aperture values and actually see the effects on the pictures. This doesn't occur with the shutter speed though.
Is this a feature of this pentax? Is this related to the ND filter in the camera?
I would really appreciate if you answer my questions so I can use the warranty policy or just try to adjust myself to the camera.
Thank you so much!
08-30-2013, 06:22 PM   #2
In M mode, you use the scroll wheels on the camera to adjust the aperture. At the wide end, the available F stop numbers will be much smaller than when zoomed in. In other words, most light is able to pass through the lens when zoomed out than when zoomed all the way in.
08-30-2013, 06:28 PM   #3
Thank you Adam for your reply.
I scroll the wheel to change the f value as shown in the operating manual, the issue is that there are only two values available. Right now they are 3.1 to 9.7. I scroll very carefully, just one "click" and there's no fine tuning. I'm not sure if I explained myself clearly. If I want a determined f value I just can't set it. With the shutter speed there's no problem at all.
08-30-2013, 07:11 PM - 1 Like   #4
Sounds like a problem that might require warranty service, or a return to where you bought it. The Av settings should scroll smoothly, just like you say the shutter speeds do.
As far as I know, the X-5 does not have a built-in ND filter.
08-30-2013, 07:23 PM   #5
Thank you Tanzer
Thank you for you reply Tanzer.
I'm not an expert, but I read in the operating manual (Specifications) this: Aperture type: ND filter.
So far, I haven't found someone else with the same issue so I guess you can be right and I might require warranty service.
08-30-2013, 08:05 PM - 1 Like   #6
no se el caso especifico de la x-5 pero artas camaras compactas solo te tiene dos seteos para la apertura (una opcion full abierto y una cerrado) y cambia el valor dependiendo la distancia focal (el zoom) que tengas puesto, a mas zoom mas grande el numero f, osea menor apertura, osea menos luz.
08-30-2013, 08:29 PM - 1 Like   #7
QuoteOriginally posted by Didi Cannucci Quote
I should rescind my earlier comment. You may be right about the X-5 having some sort of ND filter, based on a recent comment another member which was posted here:
Pentax X-5 - Pentax Compact Digital Cameras - Pentax Camera Reviews and Specifications
I'm used to using the X90, which definitely does not have an ND filter, and whose manual controls for aperture and shutter speed are actually quite good, and behave as expected. But I should not assert that the X-5 works in a similar fashion.
So anyhow, I am not sure if what you are experiencing is normal or not. Good luck!
08-30-2013, 11:04 PM   #8
This is quite normal. As already said, the X-5 (along with many lower-priced cameras) uses an ND filter instead of actual aperture blades.
08-31-2013, 06:39 AM   #9
QuoteOriginally posted by Giklab Quote
Hi Giklab, so you're saying it is normal I can't set a F-value in the M mode but this camera has only 2 f-stops....so, no need to require warranty service? There is definitively no aperture control?
Thank you for your reply.
08-31-2013, 07:32 AM - 1 Like   #10
Yes it's normal. You can only use the lens wide open, and use the ND "aperture" when you would usually stop down. Happy shooting.
09-01-2013, 03:40 PM - 1 Like   #11
Thank you!
camera, jumps, mode, pentax, pentax help, values, x-5
Abstract A few flower pics with the Pentax X-5 chicagojohn Post Your Photos! 9 09-13-2013 04:27 PM
SMC Pentax F 35-70mm F 3.5- 4.5 Focus Ring Problems (It' s jammed) urssu Pentax SLR Lens Discussion 7 06-30-2013 08:55 AM
Manual Focusing Problems with the Pentax K-5 Photo Traveler Pentax K-5 15 06-28-2012 07:34 PM
What is the use of the top LCD with setting values display ? photoleet Pentax K-5 14 09-27-2011 05:53 PM
Problems with SMC Pentax-F 35-135mm F3.5-4.5 Darius4522 Pentax SLR Lens Discussion 8 11-26-2009 05:31 PM
All times are GMT -7. The time now is 05:36 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
