08-31-2013, 09:26 PM   #1
100-500mm Super Cosina lense and a 2X KAX Macro Teleplus MC7
Hi, I have a super Cosina 100-500 lense and a 2X KAX Macro Teleplus MC7, just recently bought a Pentax K200d, can I use either of these items on my camera, if so what do I settings on the camera or do I need to purchase ones that are compatable for the camera,
08-31-2013, 09:50 PM   #2
jatrax's Avatar
Cosina has made lenses for several mounts I believe so the only answer without pictures or a complete description is `maybe`.
Post some pictures of the lens including the mount and any identifying markings.
09-01-2013, 03:49 AM   #3
Stone G.'s Avatar
If you have used your lens + TC on an earlier (film) SLR, they will work on your K200D too. Below is a picture of what a vintage Cosina lens with Pentax K-mount would typically look like.
Note, that contrary to Pentax, Cosina used to black-anodize their mounts. In order for such lenses to work the same way as genuine Pentax-K and -M lenses on a modern DSLR, you will have to sand away some of the black layer, where the mount meets the elctrical contacts on your camera body as seen in the picture.
Did you get the manual for the K200D? Otherwise you should download it from here
Operation Manuals Download : Support & Service | RICOH IMAGING
to read more about how to use manual lenses on your K200D.
PENTAX K-5  Photo
09-01-2013, 02:59 PM   #4
the Cosina lens is the k- mount fitting and the contacts looks the same as in the photo, it fits on the camera ok but when I push the shutter button down it doesn't click of, I've only had the camera a week or two so guess I need to study the manual more to find out how to make it work and maybe do what you suggested by sanding a little away of it, it also seems to focus a lot clearer on the k200d than on the MZ5
09-01-2013, 03:16 PM   #5
Stone G.'s Avatar
QuoteOriginally posted by oldenFJ Quote
Observe these three things first of all:
1. Set "Aperture Ring Permitted" in the Custom Menu of your K200D - otherwise the camera will not fire.
2. Unless you sand the black layer away, you can only use manual focus. So your AF/MF switch must be in the M-position. Once you have sanded the mount, you may set the switch in the AF position and set the AF-mode to AF.S in the camera Record Mode. That way you can have catch-in-focus (if your lens is sharp enough and the light is good enough).
3. With these old lenses you must set the shooting mode to M(anual) on the program wheel on your camera.
You should also study these guidelines:
https://www.pentaxforums.com/forums/pentax-beginners-corner-q/110658-using-ma...x-dslrs-f.html
https://www.pentaxforums.com/forums/pentax-beginners-corner-q/60081-usage-green-button.html
Happy shooting - and do share some photos with us once, you have your system working!
09-01-2013, 04:21 PM   #6
Thanks so much for your help, went out 6am this morning with a swiss girl staying with us to New Brighton beach to catch the sun rise, she got some good shots but my camera died due to flat batteries my fault for not having a spare set with me
2x, camera, kax, lense, mc7, pentax help, teleplus
Kenko 2x Teleplus Macro MC7 with FA 50 f/1.4 hinman Pentax SLR Lens Discussion 24 08-18-2013 06:01 AM
For Sale - Sold: 2x KAX Macro Teleplus MC7 doubler / teleconverter davidxgreen Sold Items 3 02-06-2013 03:22 AM
Kenko AF 2X Teleplus Teleconverter 7 Elements MC7 bdparker Pentax SLR Lens Discussion 3 06-18-2012 05:30 PM
All times are GMT -7. The time now is 08:24 PM. | See also: NikonForums.com, part of our network of photo forums!
