Originally posted by sharepointalex
Hi Igor,
Have you played around with this combination any more? I think you'll find the flash still doesn't pickup the zoom of the Tamron lens. I also have the 17-50 with the same flash and it doesn't pick up when this lens is zoomed to 70mm. It seems it's a limitation of this particular lens that it doesn't send the info to the flash.
Alex
Hi Alex,
when I asked about this I didn't read the manual yet, after reading the manual I realised that nothing was wrong with the lens nor the flash. ( well, in my case) If you tilt the flash vertically or you use the difuser then the flash goes for full power and doesn't care anymore about the settings of the lens. When I encountered this problem I had the difuser out...
Most of the time I read the manual when I buy something but that time I didn't...
I hope your problem is as simple as mine...
shoot away!
Igor
