09-11-2013, 04:11 PM   #1
camerons's Avatar
Alpa Lens on my Pentax
Earlier this year I inherited some camera gear from my Grandmother. The list of stuff is:
- 9d Body
- Schneider Alpa Tele-Xenar 1:3.5/135 in Original Box w/ caps and hood
- Schneider Alpa - Curtagon 1:2.8/35 in Original Box w/ caps and hood
- Kern-Macro-Switar 1:1.8/50 AR w/ front cap and hood
Also have a set of genuine extension tubes.
So after much research I decided that there isn't really any hope of adapting these to a pentax because the Alpa bodies were designed so that they could take various brand lenses. Therefore the lenses designed to fit directly have no hope of fitting anything else.
However, I thought I'd ask the resourceful people on these forums to see if there are any ideas?
I have bought an adapter to connect them to my brothers NEX and I have thought about getting an NEX just to use these but I'd rather not. I'm also in the middle of putting a roll of film through the camera to see how it turns out.
Here are a few photos:
50mm:
Crazy amount of focus throw:
35mm:
135mm aka "The Tank":
9D with 50mm:
Photo taken with the 50mm on the NEX. Had to use the on board flash.
There is fungus in all of them. The 35mm is the worst. But they still produced clean images on the NEX.
How about if I was able to attach one of the extension tubes to an M42 to K adapter. Would the result mean a shorter maximum focal distance?
Any suggestions would be appreciated.
09-11-2013, 04:41 PM   #2
It is a pity that the lenses have fungus, though all have an excellent reputation and would be worth taking to a reputable service person experienced with Alpa mount to be renewed. Ditto for the body.
Your Alpa was an expensive and desireable precision instrument when new. As you mentioned, Alpa did not make their own optics. Rather, they contracted with some of the best makers in Europe for optics to sell with their cameras.
09-11-2013, 05:54 PM   #3
dms
The alpa is an interesting camera--I have the same 9d, dating from 1964 as I recall. It (and the lenses) is more dated than pentax cameras/lenses--but not in quality. Topcon D, spotmatic and alpa 9d all claimed to be 1st w/ thru lens light meter. The 50mm macro switar is a superb lens. I rather doubt there is any adapter--the alpa had the shortest registration distance of all 35mm SLRs. They could take a 35mm (or was it 40mm) lens as I recall and not be retrofocus.
09-11-2013, 06:14 PM   #4
dms
I would also comment on the 135mm. I have it also except in the later lighter weight package (believe same optically)--although slow it is also excellent. Both these (50mm and 135mm) are excellent wide open!
09-11-2013, 06:32 PM   #5
camerons's Avatar
Thanks for the responses. I have found and discussed taking the gear to a local repair shop but it was going to be a fairly expensive exercise to even get them looked at. I know they are all probably worth maintaining in as good condition as possible but they are no where near mint so I am more interested in just using it rather than simply putting them behind glass. They would have been taken trekking to places such as Nepal and the Himalaya. So definitely well used.
What would be the effect of adapting the 50mm if I made the adapter as short as I could? Would it still be usable as a macro? This is probably what I am most interested in as I don't currently have a macro in my lens lineup.
I'm also trying to find out what my Grandmother has done with her Leica gear that she replaced this kit with.
09-11-2013, 09:22 PM   #6
dms
If you mean on the pentax, as the alpa registration distance is (as a guess) about 10mm less than Pentax (there are tables of these for alpa, pentax etc.--do a search), a very (!) short adapter would mean essentially m=0.2 when lens is set to infinity (10mm/50mm=0.2). And at closest the lens has m=1/3 as I recall, so it will now be 1/3*50+10~26mm, or about m=0.5. So it covers m=0.2 to m=05, about. You have Alpa extension tubes--so it will take you to very large m. But this is not auto--unless you use a double cable release (Alpa had a nice one).
09-11-2013, 10:27 PM   #7
Lowell Goudge's Avatar
Why not go outside the Pentax family and look at some ody else's ILC, perhaps there is one with an adaptor that can easily be modified. Pentax Q would be a likely candidate except the sensor is so small the crop factor would really be an issue, but there are some rather large sensor ILC cameras with short registry distances out thre
09-12-2013, 03:15 AM   #8
gordon_l34's Avatar
QuoteOriginally posted by camerons Quote
Hi,
Give f16 a ring at Margate. His phone number is 07 3284 1588.
Regards.
09-12-2013, 03:16 AM   #9
gordon_l34's Avatar
PM Sent
09-12-2013, 03:21 PM   #10
@dms
Your guess about registration difference was good: In fact it is 7.66mm
So the range for macro may be a bit wider.
Register:
Pentax 45.46
Alpa 37.8
09-12-2013, 03:50 PM   #11
camerons's Avatar
QuoteOriginally posted by dms Quote
Hi, thanks. I think I'll just have to do some research so I understand what's going on here (I'm not sure what m is above). I just stopped down the lens while pressing the shutter on the NEX.
Thanks, that is definitely an option. But that costs money which I don't really want to spend at the moment.
QuoteOriginally posted by gordon_l34 Quote
PM Sent
Thanks Gordon. PM replied
50mm, adapter, alpa, extension, hood, hope, lenses, nex, pentax help
My CPC Auto Zoom lens got stuck on my K20D mulberrybean Pentax SLR Lens Discussion 6 10-01-2014 01:37 PM
HELP! My Pentax Bellows II mounting plate is stuck on my camera. grimmy2016 Pentax K-r 2 04-07-2012 06:47 AM
Albinar Lens Stuck on my Pentax K2000 TeddyRoll Pentax SLR Lens Discussion 11 02-05-2012 09:34 AM
Why won't my lightmeter on my Ashai Pentax 6x7 work? yoav Pentax Medium Format 4 10-21-2011 05:35 PM
HELP! Canon adapter stuck on my Pentax lens tomaplaw Troubleshooting and Beginner Help 2 07-12-2011 01:05 PM
All times are GMT -7. The time now is 09:47 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
