09-13-2013, 08:52 AM   #1
Sigma lens with wiggle / wobble
What is causing this issue with a Sigma 100-300mm f4 lens? And is it repairable? We won't get into the ethics of someone selling this lens without disclosing the issue..... yet. That will be another topic. So until I find out the nature of this problem, I am vacillating between pretty disappointed (if it's easily fixable) to completely irate. Here's how much it wiggles.....
Thanks in advance for your replies.
09-13-2013, 12:19 PM   #2
sholtzma's Avatar
Don't know if it's the same issue, but my very old original version Sigma 70-200mm f2.8 had developed considerable "wiggle". I got concerned enough to send it to sigma for repair/tightening/etc. They easily fixed it (for free, mind you--thank you Sigma) and it has the tight tolerances that it used to have.
Hopefully, your problem will be that simply rectified. As for the seller....
09-13-2013, 12:43 PM   #3
Action Jackson's Avatar
If Sigma can fix, then seller pays for shipping and repair or offers refund.
09-13-2013, 03:17 PM   #4
I sent Sigma a link to the clip and they said that they can fix it so I will send it in. Also, after I contacted the seller, they said they would make it right. Apparently their son had been using it for the last several months and they new nothing of the problem. Hopefully in a few weeks I'll be smearing the forums with awesome photos from the newly repaired Sigma. In the meantime, I gotta start lifting weights...that thing is heavy.
lens, pentax help, sigma, sigma lens
DA 40 Limited lens wobble jddwoods Pentax SLR Lens Discussion 17 02-23-2014 01:30 PM
Lens mount wobble (rotation) on K5 MoiVous Pentax SLR Lens Discussion 3 05-18-2013 07:02 PM
wobble on the last lens element of the DA 15mm nirVaan Pentax SLR Lens Discussion 2 05-07-2012 08:37 PM
Used FA 43mm lens barrel wobble - is it normal? hagiri_11 Pentax SLR Lens Discussion 7 04-25-2012 09:57 AM
Pentax SMC-M 50mm f1.4 lens barrel wobble Dan Chang Pentax SLR Lens Discussion 8 12-30-2011 10:22 AM
All times are GMT -7. The time now is 03:27 AM. | See also: NikonForums.com, part of our network of photo forums!
