09-15-2013, 02:18 AM   #1
Neville's Avatar
Tv mode not maintaining shutter speed
I have noticed that, when setting my K-5II to Tv mode, the shutter speed that I set seems to change as I shoot. I was under the impression that Tv mode uses a fixed shutter speed and that the aperture and ISO would change accordingly.
Any ideas as to why it would be doing that?
09-15-2013, 03:14 AM   #2
VisualDarkness's Avatar
What lens are you using?
09-15-2013, 03:25 AM   #3
calsan's Avatar
Check your custom settings:
Auto EV compensation should be set to OFF.
If it's on, it "saves the day" by "fixing" your "incorrect" exposures.
09-15-2013, 03:57 AM   #4
Digitalis's Avatar
...that or you're accidentally bumping the E-dial that controls the shutter speed.
09-15-2013, 05:50 AM   #5
Neville's Avatar
QuoteOriginally posted by calsan Quote
That was it - thanks!
When I couldn't use Tv, I resorted to TAv mode, and allowed my ISO setting to float, which worked well for me. In fact, now I think I prefer TAv mode to Tv mode, as I can set both the shutter speed and the aperture.
09-15-2013, 05:51 AM   #6
Neville's Avatar
QuoteOriginally posted by VisualDarkness Quote
It didn't matter which lens I was using.
09-15-2013, 05:52 AM   #7
Neville's Avatar
I doubt it, but it's possible I suppose...
09-15-2013, 07:21 AM   #8
QuoteOriginally posted by Neville Quote
I also have found the TAv mode very useful
09-15-2013, 08:47 AM   #9
aleonx3's Avatar
Tv mode is meant to allow you to set the shutter speed when the camera meters for proper exposure (changing aperture for a given ISO). In the normal operation, the ISO is fixed unless you change to auto-ISO. Therefore, if you have the camera set to low ISO, the camera tries to set the proper exposure by changing to the widest aperture value first, and if it is still not enough it will lower the shutter speed to obtain the proper exposure - remember you have the ISO value set to "fixed" instead of "auto. I doubt that you have bumped the control of the dial... it is by design how Tv mode works.
09-15-2013, 09:23 AM   #10
Good that it was that easy!
change, mode, pentax help, shutter, tv, tv mode
Shutter speed mode using manual lenses WangJianWei Pentax K-01 2 06-11-2013 11:37 PM
Video mode and manual shutter speed/ISO ? alamm001 Pentax K-01 10 12-12-2012 04:49 AM
Shutter speed in P-TTL mode Twarp Flashes, Lighting, and Studio 35 02-22-2012 05:01 PM
K-x Av mode shutter speed question macky112 Troubleshooting and Beginner Help 9 03-24-2010 10:13 AM
How to achive Tv (Shutter priority mode) for K mount and M42 lenses? Sudhakar Pentax SLR Lens Discussion 12 06-03-2009 09:51 PM
All times are GMT -7. The time now is 03:47 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
