09-16-2013, 07:59 PM   #1
K5II V1.05 Firmware Update Problem
Been trying to do the new update.
When I do the For Windows : k5_2_105.exe 10,133Kbytes, LHA type, self-extracting files it downloads V1.04 instead of V1.05
When I do For Windows/Macintosh : k5_2_105.zip 10,062Kbytes, zip type nothing downloads. No file to unzip.
09-16-2013, 08:31 PM   #2
jatrax's Avatar
There is a problem with the Windows .exe it appears they have the wrong file on the web site. But the Macintosh file should work, it did for me. Download it and unzip.
See this thread: https://www.pentaxforums.com/forums/pentax-news-rumors/236799-new-firmware-k-...-645d-out.html
09-17-2013, 06:16 AM   #3
G and T's Avatar
The K5IIs firmware file is also the same. Just the same as jatrax,I downloaded the Windows/Macintosh file and unzipped that and it worked fine.
Glenn
09-17-2013, 08:16 AM   #4
I tried that too, downloading the Windows/Mac file, but when I go to unzip it I get the "no file found" message. Not sure what I'm doing wrong.
09-17-2013, 06:29 PM   #5
jatrax's Avatar
QuoteOriginally posted by moparjer Quote
What size is the zip file after you download it? Just to check your download went OK. If it is the same as the original then next question would be what are you using to unzip?
09-17-2013, 09:37 PM   #6
Check your antivirus software maybe its in the quarantined file. If I remembet it right, I got a pop up from my antivirus software whwn I tried to extract the file.
09-17-2013, 10:27 PM   #7
jatrax's Avatar
I did too now that you mention it.
09-18-2013, 01:11 AM   #8
Thanks for all the replies everyone, I finally figured out what I was doing wrong.
downloads, pentax help, type, v1.05
K30 freezing since firmware update 1.05 poziax Troubleshooting and Beginner Help 12 02-02-2014 05:00 PM
K-01 Firmware update - V1.02 Docrwm Pentax K-01 42 05-04-2013 06:04 AM
Firmware Update K-5 V1.14 Docrwm Pentax K-5 109 03-29-2013 05:53 PM
K5II K5IIs firmware v1.03 update LFLee Pentax DSLR Discussion 2 03-07-2013 08:19 PM
Firmware update v1.01 for Q10 Mistral75 Pentax Q 3 02-20-2013 03:55 AM
All times are GMT -7. The time now is 10:14 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
