09-26-2013, 09:00 AM   #1
Autofocus problem
I've had my K20 since they were introduced and it has been hassle free.
However on holiday in the US recently I was (and am) unable to use the AF in Single shot mode. The camera will just not focus. Its fine in Continuos and Manual. I've checked everything I can think of and re-set to factory setting but to no avail. It is not the end of the world but I'd just like to work properly!
Regards
Stephen
09-26-2013, 12:34 PM   #2
When pressing the display button, does it show that you are in AF mode with in AF single position?
09-27-2013, 11:11 AM   #3
Na Horuk's Avatar
Hmm odd that AF.C would work, but not AF.S. Charge up your battery, leave it outside the camera for some hours. Clean the lens and camera mount so its free of grime. Maybe try a firmware update.
Also, the reset to factory defaults should have fixed any menu choices, but look at the AF menu settings once again just in case.
pentax help
ist DL autofocus problem sailorman Troubleshooting and Beginner Help 4 10-12-2012 07:12 PM
K-x Autofocus Problem shahnc Troubleshooting and Beginner Help 2 10-09-2012 11:49 AM
Autofocus problem. psyrim Ask B&H Photo! 6 08-10-2011 06:09 AM
SFXn autofocus problem Radix Pentax Film SLR Discussion 3 02-22-2010 06:10 AM
Autofocus problem with K10D Old Timer 56 Pentax DSLR Discussion 18 07-05-2008 01:21 PM
All times are GMT -7. The time now is 12:59 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
