09-26-2013, 01:05 PM   #1
Lester A. Dine Macro ring flash adapter deattach
Hello. I have the Lester Dine (or maybe Nissin) ring flash with PT-2D hotshoe adapter. The same as on the picture. I want to know how to deattach this adapter if in future I will change the camera etc. It should be changeable but I did not found any buttons, screws etc to easily unlock it.
Thank you.
09-26-2013, 02:35 PM   #2
p38arover's Avatar
It looks identical to my Sunpax Auto DX8R ring light flash with the PT-2D Pentax adapter.
I suspect that you may need to unscrew the 2 Phillips (or JIS) screws at the bottom of the hotshoe. Alternatively, the PT-2D nameplate may cover some mounting screws.
09-26-2013, 02:41 PM   #3
bluestringer's Avatar
Yes, it is identical to my Sunpak DX-8R. There is a lever inside the battery compartment to remove the module.
09-26-2013, 02:42 PM   #4
Open the battery door and look for a lever or slide that you can pull out a bit with your fingernail. That should allow the hotshoe module to drop free from the rest of the flash.
09-26-2013, 02:53 PM   #5
p38arover's Avatar
Well. I never.....
.....noticed that lever before. Thanks.
The fit of the module is so good that it's almost impossible to see it's an add-on.
Oh, I love the label UNDER the module tell you to open the battery door before changing the module!
09-27-2013, 01:18 AM   #6
Thanks for all. I have opened the battery door and found a sticker on the bottom. When I removed it, there was a hole and really some kind of a tiny lever. I think it's this thing. But it's black and I can't move it at all. I have tried with nails and screwdriver.
09-27-2013, 02:34 AM   #7
p38arover's Avatar
QuoteOriginally posted by Spamer Quote
Are you trying to move the item circled? As far as I can see, that's just a locating pin that forms part of the locking mechanism.
Why are you trying to move it?
09-27-2013, 02:41 AM   #8
There is only one way I can move it. The hole is long. Sorry for the quality, but it's probably the best I can do.
09-27-2013, 02:49 AM - 1 Like   #9
p38arover's Avatar
To remove the adapter, open the battery door and you will see a piece of silver metal near the edge of the door. Slide that out about 2mm and that will release the catch. Whilst holding it out, wriggle the adapter off the flash unit.
PENTAX K-5  Photo
09-27-2013, 02:52 AM   #10
Oh, I did it. Thank you very much. What a genius piece of plastic and metal. I really like both it and Adaptall 2.
adapter, deattach, flash, lester, pentax help
For Sale - Sold: Lester Dine Auto-Macro-Light Ring Flash - (Sale Pending) HogRider Sold Items 12 09-14-2012 05:37 PM
For Sale - Sold: Lester A. Dine 105mm f/2.8 Macro lens, Ring Flash, ZX-50 (kit or separately) macTak Sold Items 4 09-12-2012 07:48 AM
Lester Dine ring flash battery / ac adapter / power supply BradleyS Pentax Camera and Field Accessories 10 07-26-2012 02:17 PM
For Sale - Sold: Macro Ring Flash for Vivitar/Kiron/Lester A Dine bonovox Sold Items 7 09-25-2008 08:26 AM
All times are GMT -7. The time now is 09:44 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
