10-04-2013, 10:49 AM   #1
Cokin P question
Hello,
I tried to search the forum and used the search site as well, but could not find anything related to it.
Just received my cheap cokin p ND filter set but something bothers me. It seems like there is 4 slot, but can't slide the filter into the first slot.
I thought the ND filter supposed to be flush with the lens so no light can leak into the lens.
I attached the image so make sure you guys can see what I'm talking about. I put a filter into the first slot! arrow pointing to the questionable space there.
Something supposed to be there?
Cheers,
Viktor
DMC-LX5  Photo
10-04-2013, 11:36 AM   #2
The slot you are referring to is intended for a solid black blind if needed.
10-04-2013, 11:40 AM   #3
mikeSF's Avatar
I only see three slots here. that first little space may not be an intentional slot
10-04-2013, 11:46 AM   #4
Like this:
10-04-2013, 11:47 AM   #5
QuoteOriginally posted by aoeu Quote
I think I saw a video that someone had a lens protector in there.
Anyways, will I have a light leak there since there is a space in between the lens and the filter?
Is this normal?
Thanks
Viktor
10-04-2013, 11:50 AM   #6
Like this:
Cool!
Thanks for the great pic!
So I'm guessing it's ok to have a space in between the filter and lens?
10-07-2013, 02:26 PM   #7
Wingincamera's Avatar
That first slot is where the Cokin PL is placed, at least on mine.
10-07-2013, 03:16 PM - 1 Like   #8
skunktail's Avatar
As others have said,
This slot fits either the cover or a "sprocket" filter (usually a polariser)
I've never noticed significant problems with mine if I leave it empty.
10-24-2013, 04:43 PM   #9
MarkJerling's Avatar
QuoteOriginally posted by skunktail Quote
Yup, I have one too. no need to worry about it.
10-24-2013, 11:19 PM   #10
adwb's Avatar
That's there for a polariser with the etch on the edges so you car rotate it
10-29-2013, 01:59 PM   #11
The first slot is not just for polarizers. Its for any type of filter that you might need to rotate, such as a star filter or multi-image refractor.
cokin, filter, lens, pentax help, search, slot
Cokin P Series Holder cali92rs Pentax Camera and Field Accessories 10 05-27-2012 02:34 PM
Cokin Filter Holder P + 40mm Pancake? Kirei Pentax Camera and Field Accessories 6 11-07-2011 12:29 PM
Cokin P series 62mm adaptor ring rebelcruiser Pentax Camera and Field Accessories 2 10-23-2011 05:19 AM
cokin filter system question gokenin Pentax Camera and Field Accessories 13 10-11-2010 10:14 AM
Question on Cokin Blue/Yellow Filter Use. Chako Photographic Technique 6 10-16-2007 11:52 AM
All times are GMT -7. The time now is 05:00 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
