Originally posted by Okeydokey
I find it ihard to understand why the Pentax M42 adapter ring is so much more expensive than the grey versions, fleabay throws them out at a few pounds (UK), for the grey versions. I now have a 55mm f1.7 Chinon on its way and the jury is out on the 500mm. I have a scope and have always been in two minds about a large low cost, previously owned lens. Thanks for all your advice!
I have a decent 500mm f8 mirror lens. I think one reason people use telescopes instead of lenses is that the scope already has a tracking mount. I can get some decent shots of the moon but that's pretty bright. Still I have to raise ISO at 500 or using a TC to get 1000mm, just because the moon moves pretty fast across the frame. Faster 500mm lenses are around but not in my price range.
On the adapter, the Pentax one at least shows you how the thing was meant to work. I have some broken cameras and old lenses to test out off-brand adapters, and most of them will work eventually. If you don't want to adjust and file and pray to the lens gods to get the lens off your DSLR, maybe the extra cost is worth it.
