10-06-2013, 07:42 PM   #1
Lens hitting the mirror? K5 IIs
I just noticed some nicks / spots through my view finder. The spots, 3 of them, are each near a separate corner. One looks pretty bad, like a gouge. I tried blowing them off with some air, then brushing them off, but they are still there. I didn't think there were lenses that were dangerous to use in the realm of Pentax.
10-06-2013, 07:53 PM   #2
jatrax's Avatar
Picture?
You say you see them through the viewfinder, if you take the lens off and look at the mirror can you see them?
10-06-2013, 07:57 PM   #3
JinDesu's Avatar
What lens are you using?
10-06-2013, 08:05 PM   #4
They're still there with no lens. I noticed them today, but I know that it couldn't have happened today because I was using M42 / screwmounts (one of them was a 100mm f/3.5 Takumar screw mount from 1957). Maybe I can take a macro, and post it. Thanks.
10-06-2013, 09:10 PM   #5
Here is a photo that I took through the camera mount.
10-06-2013, 09:15 PM   #6
bossa's Avatar
looks like oil spots
10-06-2013, 09:18 PM   #7
They do not look like mirror/lens interference. I'd try blowing them off, and keep in mind that they could be under the viewfinder screen or in the viewfinder itself.
10-06-2013, 09:25 PM   #8
jatrax's Avatar
Are you sure those are on the mirror? Looks more like they are on the focusing screen. And as noted above can be under the focusing screen and not easy to get to without removing the screen.
And I agree they don't look like lens interference more likely dirt/dust/grease/oil.
10-07-2013, 12:02 AM   #9
Okay, I didn't know about that. I did have an oil spot on the sensor when I bought it. I had that fixed.
pentax help, spots
Best lenses for the K5-IIs kuau Pentax SLR Lens Discussion 21 11-30-2014 08:24 PM
New K5-IIs and lens arrived. Question? gaweidert Pentax K-5 4 04-25-2013 03:42 PM
K5 IIS and M42 Lens woodssiam Welcomes and Introductions 4 02-24-2013 12:37 PM
How Different are The II and IIs from the K5 Classic? Franklin Pentax K-5 8 11-29-2012 10:18 AM
K5 + Sigma 600mm Mirror Lens Tonypandy Visitors' Center 5 03-28-2012 09:49 AM
All times are GMT -7. The time now is 02:11 PM. | See also: NikonForums.com, part of our network of photo forums!
