10-12-2013, 02:18 AM   #1
K-m power supply
I'm no electrician or electronics buff, but I am trying to make an ac adapter power supply for my K-m, sometimes referred to as a battery eliminator.
I have sourced the two AAA - AA battery containers to fit things into, but can't put my finger on the exact amount of Volts and max amps I should be heading for, or indeed a low cost power supply unit to use for this.
Any idea on safe tolerances for the amps? I suspect 2 amps would be fine with 5.5V supply, but that is more guess work than informed thinking
Many thanks
10-12-2013, 06:11 AM   #2
The official one is 6.5V and 3A.
10-12-2013, 07:59 AM   #3
JimJohnson's Avatar
QuoteOriginally posted by elliott Quote
Let's use this as a start. Voltage is the amount of electric pressure in a circuit. 4 AA batteries in series will put out about 4.8 to 6 volts when fresh, depending on the chemistry involved, and the voltage falls slightly as the batteries are used. So 6.5 VDC (volts direct current) reflects the high end of those values. I would suggest that a power supply with an output between 6.0 and 6.5 VDC will do the job.
Amperage is the amount of current available. That last word is important. The official power supply can supply upto 3A (amps). It does not mean the camera's circuit uses 3A continuously. It uses only as much current as needed for the current operation. To play it safe, the power supply for this project should support output of at least 3A. Greater than 3A won't hurt anything; it just means the power supply won't work as hard.
If you want to see how I tackled this project for the K-r, K-30, K-50 or K-500, check out this DIY article:
https://www.pentaxforums.com/forums/do-yourself/217023-build-ac-adapter-pentax-k-r-k-30-a.html
10-12-2013, 12:48 PM   #4
Many thanks guys. I am sure with your contribution I can crack this with alot more confidence. JIm many thanks for clearing that up for me, very well explained!
battery, camera, k-m, pentax help, photography, power
External power supply mattv Pentax K-5 12 12-22-2012 07:35 PM
DIY K-5 Power Supply from 12V battery atnbirdie Pentax K-5 19 12-14-2012 10:18 AM
Lester Dine ring flash battery / ac adapter / power supply BradleyS Pentax Camera and Field Accessories 10 07-26-2012 02:17 PM
K-5 power supply orangezorki Pentax K-5 7 04-19-2012 04:49 PM
Charger/Power Supply jnorth Pentax DSLR Discussion 15 01-07-2007 10:47 AM
All times are GMT -7. The time now is 06:27 AM. | See also: NikonForums.com, part of our network of photo forums!
