Originally posted by jatrax What model flash? I use my Sb-26 on the k-5 with no problem. The flash must be in manual mode as the k-5 does not use TTL flash communication, which the older flashes do. If you have a newer flash it still must be in manual as it will use the Nikon protocol and the k-5 will use P-TTL.
So they will work, but only in manual flash.
Also, be aware some older flashes can use a voltage high enough to damage modern cameras. If your flash is relatively new this should not be an issue, but if it is old you should check the voltage first.
Hi, I have Nissin Di466 for Nikon. Of course I'm aware, that it should work only in manual mode.
So I have my flash attached to camera, set into manual mode and ... nothing.
Some other setting should be done ?
