Originally posted by patrick9 When using a rocket blower I always blow it into the air to rid it of the dust that can settle in it when not in use. Then I blow my sensor and interior of the camera.Be careful not to touch the sensor with the blower .I hold the camera lens opening down so that dislodged dust falls out and not around or back into the camera. I have never had the dust resettle on my sensor doing it this way. I also am careful at lens change.Keeping the camera face down when lens is removed and until lens is replaced, and out of the ,has helped in keeping the dust off the sensor.
Agree 100%.
Take care with your blower not to stick the nozzle into the mirror box and accidentally bumping against the mirror or other internal parts. Try to keep the nozzle no further in than the actual lens mount.
I have found that, sometimes, one go with the blower gets the dust most of the time, but sometimes, a stubborn bit of dust, maybe something sticky like pollen etc, may need multiple attempts. So far, I've not had any dust that has not come off with the blower or using the camera's dust clearing function. I have, to date, not needed to do any more 'invasive' sensor cleaning.
It's good to remember that dust largely adheres to surfaces because of electric charge. (Static) As noted by others above, there are options available where a special brush can be twirled around to stimulate a static charge thereby 'sucking' the dust off the camera surfaces. I've not tried this myself but if I build a desk "blower", I'd be keen to combine it with a static inducing wand to see if that would help.
