10-20-2013, 11:59 PM   #1
K10D problem...Help, please
Hi. I have a K10D which I still love to bits, but I had a stroke some time ago, and haven't used it in ages, mainly because the stroke robbed me of my strength and affected me ability to hold such a hefty camera (now I use a Olympus E-PL1which is much lighter). But, today I tried using the Pentax with a tripod...and that's when the problem happened.
I fixed a 50mm FA lens to it, replacing the previous Sigma10-20mm, turned the camera on, but the shutter refused to work. I kept getting an "F - - " flashing in the top window which is split into five boxes. The flashing was happening in the top left hand box. I have obviously done something wrong....
HELP
10-21-2013, 12:08 AM   #2
Not a Number's Avatar
The aperture is probably not set to "A" and "Use Aperture Ring" is not enabled in the setup. Setting use of the aperture ring will allow stop-down metering. Setting the lens to "A" mode will allow all metering modes.
10-21-2013, 12:29 AM   #3
Thanks, Not A Number....um....but since the stroke we have moved states and in the move I lost all my K10D documentation...as well as parts of my memory....how do I set the aperture ring... I know this makes me sound like a dummy... but strokes can do things like that :-(
10-21-2013, 12:30 AM   #4
QuoteOriginally posted by Darius4522 Quote
Just turn the ring on the lens (the one with many numbers) all the way to the "A" position.
10-21-2013, 12:42 AM   #5
There should be a little button on the aperture ring that you need to press to allow the ring to turn on or off the "A" setting.
10-21-2013, 12:47 AM   #6
On the lens and on the aperture ring there is the letter "A" to the left of the aperture numbers. A bit further to the left of the "A" there is a small button, that you need to push down while you turn the aperture ring to the "A" position. This enables you to let the camera control the aperture automatically and you to control/adjust the aperture from the rear thumb wheels. The aperture is also reported to the LCD window up on top of the camera.
Also, here is a soft copy of the K10 User's Manual that you can keep on your PC's desktop for reference.
Hope you are making a good recovery....
10-21-2013, 04:58 AM   #7
Thanks for your help, everyone.....it all came back to me after reading your advice! The K10D is working like a dream again! I'm indebted to you all.
camera, k10d, pentax help
Help with K-x Problem, Please? Jennifer K. Visitors' Center 3 07-20-2013 07:44 AM
istDL... MAJOR PROBLEM... Please Help!!!! Bedlam Troubleshooting and Beginner Help 28 09-10-2012 08:46 PM
gemini 28mm lens problem/question please help chris* Pentax SLR Lens Discussion 4 03-22-2012 12:46 AM
Please help me fix my K10D's focus problem Hannican Pentax DSLR Discussion 10 02-01-2009 03:08 PM
HELP PLEASE !!! Bizarre K10d exposure problem!! StephenG Pentax DSLR Discussion 15 10-02-2008 12:52 PM
All times are GMT -7. The time now is 07:43 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
