In regards to M-mode being locked in Hyper-Manual when flash is used. This is not making good sense. Back to step one here:
- Did this all used to work?
- Are you new to the K20D?
- What lens are you using?
- Does this happen with all lenses?
- Is this a problem when not using the built-in flash?
- Is everything else in the camera working properly?
Finally (or perhaps first)...
In the viewfinder, do you see a green * at bottom to the right of the over/under graph? The * is the indicator for AE-L and if lit in M-mode indicates you are in hyper-manual mode. Depending on how you hold the camera, the AE-L button can be pressed accidentally. I was wrong in my above comment regarding exit from hyper-manual mode. You exit by pushing the AE-L button or by turning the camera off.
Except for hyper-manual, I don't know of any setting that will do what you describe. Stuck-down contact on the mount face? The "A" contact (third from left, camera facing you) is always slightly recessed.
